1970 OAI hood question?
Old Feb 9, 2010 | 03:02 PM
jensenracing77's Avatar
i am told that you can cut the frame out of a steel hood and glue it to the fiberglass of an OAI hood that had the frame rusted out. is this true? it looks like it would work. i have a 1970 flat hood that has zero rust on it. i was saving it to use the frame if i ever needed it to fix an OAI hood if need be. i was thinking about selling it but for no more than i can get for it i am thinking i will just keep it for this reason. what did the factory use to glue them together?
Old Feb 9, 2010 | 04:04 PM
svnt442's Avatar
I think the issue you may run into the the frames are different due to the large hole for the air box. It might look good with it closed, but it wouldn't be functional.
Old Feb 9, 2010 | 04:16 PM
ent72olds's Avatar
Registered Luser
Eric, if you still have the OAI hood on your Rallye, you could compare it to the hood you have...if they match up, you're good there! Although separating the glass skin from the steel skeleton might be risky! Could do more damage than good!there are plenty of products that you could glue with. 3M and Fusor make some good panel bond adhesives....look it up on the net!
Old Feb 9, 2010 | 04:32 PM
Bluevista's Avatar
Registered
Somebody here or on one of the other Olds forums was talking about taking their OAI hood to Thorntons and having the skin seperated from the frame.
It was either to re-glue it or put a new steel frame on?
That panel glue woud probably do the trick like Erik said, and he knows, about that stuff anyway.
I would use Liquid Nails myself.
Old Feb 9, 2010 | 04:36 PM
ent72olds's Avatar
Registered Luser
You carpenters are all alike Allan.....Liquid Nails on everything! I thought you were a duct tape guy!
Old Feb 9, 2010 | 04:50 PM
cutlassgal's Avatar
Cutlass Lover
He's fickle... amongst other things!
Old Feb 9, 2010 | 04:54 PM
i was going to compare it to the rallye but the hood is behind a days worth work to get it out. i think the area for the air breather is open on the steel hood. the one thing i am also wondering is the spot for the hood pins. i will just have to look at them.
Old Feb 9, 2010 | 04:59 PM
Bluevista's Avatar
Registered
I buy it by the case, in the big caulking gun tubes.
At work you actually only use duct tape for ducts.
Also works well for wounds, the tinners's hands are covered with the stuff on bad days, auto body guys should all have a roll handy.
Old Feb 9, 2010 | 05:20 PM
ent72olds's Avatar
Registered Luser
Actually, you are close....we use masking tape! We call it "Bodyman's Band-Aid". And if you get stitches, don't bother coming back to work! Real bodymen don't do stitches!
Old Feb 9, 2010 | 05:34 PM
we use electrical tape.
Old Feb 9, 2010 | 05:43 PM
2blu442's Avatar
I started on a project like this years ago. I still have both the rusty frame and steel hood frame, plus the badly cracked Rallye 350 fiberglass. I thought the primary difference was where the hood pins fit, it looked like heat and using a press could create the space for the pins.
But... I know a while back there's another thread discussing this and I believe Joe said there were other differences that would cause problems. If you haven't done a search on the subject it might be worth a try. John
Old Feb 9, 2010 | 06:05 PM
i have tried the search method on other subjects, i don't think i know what i am doing with it because i never find anything with it.
Old Feb 9, 2010 | 06:18 PM
svnt442's Avatar
I have a steel hood in the garage. I can go down and snap some pics of the underside and then open my hood to give you an idea of the difference.
Old Feb 9, 2010 | 06:23 PM
442much's Avatar
OOOOOOh I get it! I thought the liquid nails option was just in case he broke one of his
Old Feb 9, 2010 | 06:46 PM
Yes, the two metal frames are not identical. It's been a while since I looked at this, but there's a formed section on the frame for the steel hood that is formed one way and the opposite way on the O.A.I. hood frame. I don't remember it this prevents using the metal hood frame on a 'glass skin, but it will not be "correct".
camshaw
May 4, 2015 11:53 AM
69ishHoliday
Body work
Nov 19, 2013 06:05 AM
Grant1424
Body work
Aug 27, 2013 09:47 AM
guy.graziano
Mar 21, 2012 09:32 AM
guy.graziano
Dec 5, 2010 12:10 PM
