1970 Cutlass Heater Hose Clamps
Old October 29th, 2010 | 06:07 AM
Del70's Avatar
I am going to install the ribbed heater hoses, with the 70 style spring style clamps The 1970 type with round wire. Has anyone had any issues getting these type of clamps to seal up. Do I need to compress the clamp once installed? Thank you
Old October 29th, 2010 | 09:26 AM
442Harv's Avatar
When I put a new cam in mine, years ago, I dicided to put the correct clamps back on. One end off the radiator hose almost blew off when braking in the cam, so I took the off, and put the band type back on. Maybe I had the wrong ones?
Old October 29th, 2010 | 10:15 AM
ROCKET VAPOR's Avatar
Lance
I glued mine on with the light gray Permatex that is sold in the small tube for water pumps and thermostat housings.
No problems with leaking or blowing off. Just make sure to give the Permatex about 24 hours to dry before adding anti-freeze to the cooling system.
197064buickspec
July 15th, 2019 05:28 AM
firefrost gold
August 3rd, 2014 12:06 AM
Octania
April 15th, 2013 09:40 AM
Del70
July 2nd, 2012 09:35 AM
bobb
October 20th, 2010 04:19 PM
