1970 heater hose clamps ??
so as the story goes I'm installing new heater hoses and clamps there are two versions the Round spring type with two large tangs and the flat steal with three tabs like a fuel line clamp . what is the consensus on witch one is right i was thinking the Round steal was till today . Inline has the other flat type in their book .
http://www.inlinetube.com/PDF%20cata...dsmobile06.pdf scroll down to page 85 in the middle
Not sure when they changed to the tower style but my 69 has the round spring style and they are original to the car. I think the resto parts dealers carry them. I don't know if it makes a difference but mine is an air car.
Cheers, Mike
Cheers, Mike
The original heater hose clamps for a 1970 Cutlass and 442 are flat clamps like the the fuel line clamps. The larger diameter clamp is black and the smaller clamp is olive green. No one is currently reproducing them accurately to my knowledge. I have found originals in wrecking yards on Buicks, Cadillacs, and Oldsmobiles.
in the 70 AM the photo show's the round type with the tang on them I think they are called a corington clamp ?? Other photos look like the flat ones . Inline does sell the round tang style black for large and green for smaller but they are round. I have other style of order will see what come's
lets see them please
what part of Minneapolis are you in I work down town 4th ave south
Cheers, Mike
^ This is what I have seen every time this topic comes up. Unfortunately if you look at the link above on page 85 they list 3 different types of heater hose clamps that will fit 68 - 70 non AC cars?
There is a thread somewhere on here that has pics of the correct clamps as stated above (black and olive) - I just couldn't find it last night.
Some interesting reading on this subject.
https://classicoldsmobile.com/forums...ct-clamps.html
BTW, I believe that INT has just started carrying the proper style band type clamps for '70 heater hoses, but the coloring might still not be correct though.
70post is who i was talking to about them . I have them on order and hope they come in by friday I can change out the corbin style that a put on Not abig deal. Thanks for the post vapor I did a search but didnt see that post .
I missed the inline tube link earlier but after looking on page 85 my 69 has the clamps that are numbered INL10814. In the description it states that these are for non air cars but I can assure you that these are original to my air car. Might be one of those screwy things that happen on assembly lines. Perhaps the bin of tower clamps happened to be empty so they all got these until someone filled the bin.
Cheers, Mike
Cheers, Mike
The first Olds aftermarket vendors I'm aware of were Fusick and Year One.
Cheers, Mike
Cheers, Mike
I find these repo clamps to not seal so well. so now in a few instances i put the gates heat shrink black clamps on the hoses,(get them at napa) wipe off the lettering and install the clamp over it for looks. tower clamps are sometimes frustrating. and once they are tight they are tough to get off.
Naw...
The pics are just to show an example (heck of a nice detail job too BTW). What kind of finish is that on the rad? It looks like hammertone to me. Whatever it is, looks really nice!
100% correct!!!!! I have a couple of original ones, the factory also used them on the water pump side of the heater hose as well.
STeve
inlines are a greenish copper look to them for the large one and flat black for the smaller clamp . The flat ones were harder to put on than the round corbin style but they look good . sealed off so far they pulled tight to the point i can see the flare in the hose .
the flat "fuel line type" are one year only for 1970 A body heater hose at both ends, heater core and water pump. check your 70' assembly manual! I have an NOS set encase mine loose tension.
