1970 cutlass front Brake drum wheel bearing size
Looking for the correct wheel bearing size for the inner and outer bearings for a 70 cutlass front with drum brakes. (Part stores list two sizes...?) thanks
Every single 1964-1972 A-body uses exactly the same front wheel bearings. Disk or drum is the same. A6 inner bearing and A2 outer bearing (or equivalent in another manufacturer's numbering system). For that matter, the 1961-63 F-85 cars also use the A2/A6 wheel bearing combo.
Del70
March 21st, 2015 09:22 AM
Del70
July 28th, 2014 03:24 AM
yeahbuddy
Brakes/Hydraulic Systems
January 15th, 2014 02:10 PM
Flye
Drivetrain/Differentials
July 30th, 2009 10:24 AM
