1969 cutlass
Old Oct 12, 2019 | 02:33 PM
72cutlass408's Avatar
1969 cutlass
How to check/verify if it was a original 4 speed car
Old Oct 12, 2019 | 07:37 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Look at the shifter is it correct?
Look at the shifter tunnel hole. Is the tunnel hacked?
Look at the serial number and date code on the trans.
If it's other than a Lansing car look for the build documents.
The steering column and speedometer are often not changed if it was originally a column shift.
Look for spliced wire harnesses and other evidence of hackery.
Does the Z bar bracket look like its been there since 69?
Is all the correct clutch linkage there?
Do the clutch/brake pedals have approximate wear for the miles on the car?
A really well-done resto is difficult to tell.
Documentation and matching serial numbers are decisive.
Old Oct 13, 2019 | 09:58 AM
rcorrigan5's Avatar
Randy C.
As well, the VIN derivative should be stamped into the driver side of the transmission housing. That will really tell if that 4-speed transmission was original to the car.
Randy C.
crystal59
Dec 13, 2024 06:38 PM
Mojo4892
Mar 20, 2016 07:32 PM
camshaw
Aug 14, 2013 02:23 PM
nanardos
Aug 8, 2013 12:53 AM
jjamm7667
Apr 19, 2012 10:18 AM
