1967 Cutlass Body Tag Questions
Old Jan 12, 2025 | 02:28 PM
Turboreset22's Avatar
Hi everyone new member here, hopefully this is posted in the right place. I am currently in the process of restoring my 1967 Cutlass and wanted to help deciphering some of the lines on my body tag. I can't seem to find info on the COSTOP29 line, what plant it was manufactured in, or what the 2-12-2 line means. I also want to note that I'm a Canadian. Help would be greatly appreciated, Thanks.
Old Jan 12, 2025 | 05:00 PM
You may have a cowl tag produced in Canada - I don't know I've seen one exactly like it.
Here's a good read by Koda...
1967 Oldsmobile Cowl Tag Information Sheet
Old Jan 12, 2025 | 05:57 PM
Oshawa tag I think.
It looks like KK and 936 transfer from American, as does the style. Body number is same format. 2-12-2 is probably Feb 12, 2nd shift.
I do not know the COSTOP 29.
Old Jan 12, 2025 | 06:24 PM
It's actually CO8TOP29
Old Jan 12, 2025 | 07:25 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
33617 = I think is Cutlass (Not Supreme) Holiday Coupe
2-12-2...build date...what Koda says make sense
OS = Oshawa
303011 is the consecutive build number.
9 = enamel paint. KK is Aquamarine poly paint. 3 KK would be the same color in lacquer.
C08 TOP29 could be vinyl roof(top) white, teal? Black is TOP27.
What color roof do you see on this car? Does it have vinyl roof trim?
936 is bench seat Aqua
Below is a 67 Chevelle Oshawa trim tag. 9 and RA = enamel paint, R being Bolero Red (lower body color) and A being Tuxedo Black (upper body color).
Remember GM of Canada was heavily Chevy based.
See this thread for a similar car US made.
https://classicoldsmobile.com/forums...roject-123203/
Old Jan 12, 2025 | 08:44 PM
OS = Oshawa
Thank you everyone for the great information! The color of the roof is mostly surface rust or brushed on black. This cars been painted a couple of times, however, yes the car did have a vinyl top at one point. It was white, I found these scraps under the trim this evening to confirm! I always assumed it had a black vinyl top. So from a production or numbers stand point is there any way to know how "rare" the white vinyl top is? Or how many Cutlass' came out of Oshawa that year?
Old Jan 12, 2025 | 09:35 PM
No problem. Glad to help.
That level of granularity not available for Oldsmobile's. We do know the total amount made but not down to specific options and colors.
Those color combos were fairly popular, though I'm told K codes were slightly rarer than say main stream colors red, white, saffron, blue. White roof nothing special.
My 68 was a K code with a white top & pearl gut (parchment) Now resale red black/black. K Its actually quite striking. If I did my car over again I be hard pressed to not go K code parchment...with no vinyl top.
Regardless its a cool car to restore. You dont see many today, especially K codes.
K code 68 with white/parchment
69 K code white w/parchment
Old Jan 13, 2025 | 05:21 AM
1967-older cowl tags were different on Canadian built cars. VINs were different also.
JuanC
May 21, 2021 10:51 AM
jberenyi
Apr 28, 2021 09:56 AM
nelly101
Jun 19, 2014 01:45 PM
jvock6
Oct 18, 2013 02:14 PM
shermanator
Tech Editor's Desk
Feb 4, 2010 09:23 AM
