1967 CS Vintage Air install air duct question
Old May 28th, 2019 | 09:01 PM
danktx's Avatar
The evaporator install instructions says to stretch the duct material out. On my install, the air plenum has (4) 2.5" connections for ducts to connect to, 3 of the 4 ducts will need to be bent beyond 120 deg. to get them routed to the dash vents. How do you stretch the duct without causing it to kink or turn a hard right angle where it attaches to the evaporator plenum. It would seem to me a hard turn would cause a restriction in air flow through those 3 ducts.
I'm looking for guidance from someone who has done this before me. What was your solution or am I just being ****?
Old May 29th, 2019 | 05:51 AM
edzolz's Avatar
I have never installed these into 67's but have done many street rod installations. The ductwork tubing has a stiff rib in it that prevents collaps when bending. As long as the connecting material isn't split, the round tube should be ok when bending. I have had to bend this stuff 180 degres and never had a problem.
Old May 29th, 2019 | 06:11 AM
I haven't "done it before you" so I guess you won't be interested in my reply, but I would lay the ducts out in the sun for a couple hours to make them more pliable.
terrysolds
July 30th, 2019 04:14 PM
96powerstroke
July 15th, 2019 01:39 PM
terrysolds
February 23rd, 2019 03:51 PM
Cpriester123
June 25th, 2016 11:31 AM
Liegekiller
October 3rd, 2011 05:32 PM
