1964 F-85 Noise in Steering Wheel
Old Apr 14, 2014 | 01:43 PM
Xavier777's Avatar
Hey everyone, yesterday my steering wheel started making a noise whenever i turn it, it sounds like scraping or like a spring. Anyone have any ideas what this could be? Thanks for any help.
Old Apr 14, 2014 | 04:22 PM
pcard's Avatar
70 Cutlass SX
Not sure about 1964, but on my 1970 sport wheel I had the same noise - it got to be a really bad screech.
I took the wheel off, and the hub (you will need a puller), locking plate and then the cancel cam. The problem was that the metal contact plate on the back of the cancel cam had delaminated. It was dragging over the turn signal lever attachment screw. I epoxied it back on tight, and ground a bit off the turn signal lever screw as well. Lithium grease for good measure.
No more noise.
If it is not that then you would need to dig deeper.
Old Apr 14, 2014 | 04:28 PM
Octania's Avatar
A '64 column is fery simple inside. No lock plate. Take a peek in there. You may need a steering wheel puller to remove it after the nut is off.
Old Apr 14, 2014 | 04:41 PM
Xavier777's Avatar
I think i'll take the wheel off, I just didn't want to because I'm worried I won't be able to line it up with the wheels perfectly
Old Apr 14, 2014 | 06:19 PM
oldstata's Avatar
Justin
Just mark it with a paint pencel or marker
Old Apr 14, 2014 | 07:06 PM
66-3X2 442's Avatar
Check the gap between the wheel and the bowl to see it it closed up somehow. The 64-66 columns are very easy to adjust and if that's the problem,I'll tell you how to adjust the gap.
MerryOlds
May 6, 2014 08:29 PM
RandyS
Suspension & Handling
18
Apr 19, 2014 08:26 PM
Benton Quest
Aug 24, 2013 03:22 PM
Don R.
Dec 8, 2012 08:21 PM
