1957 Oldsmobile Super 88 Battery Replacement
Old Aug 16, 2025 | 08:27 AM
snowmonkeys's Avatar
Unhappy 1957 Oldsmobile Super 88 Battery Replacement
Looking for a new replacement 12 Volt battery for my 1957 Oldsmobile Super 88 2 Door hardtop. Walmart = No Good, Orielly's Auto = No Good, Auto Zone = No good. Rock Auto = No good, None of these will fit the battery tray and are too tall for the factory negative cable that hooks to the block and the battery tray. Battery Central Mall = $400
Any inside info on where to get a battery that won't cost $350-$450 that will almost fit the battery tray. Dimensions are 13.5 inches long, 6 inches wide, and 7 inches tall. Could go as tall as 7.5 inches but that would be it.
Any help or thoughts?? Most batteries are too tall and too wide.
Old Aug 16, 2025 | 08:57 AM
OLDSter Ralph's Avatar
If you need a battery that is exact for a Con Cours restoration the high priced one is your choice, I think. If you just need a battery for function, take your measurements and a tape measure with you. You can probably find a current battery group type that can work.
Here is a chart to help you.
https://www.jegs.com/Sizecharts/bcig...xtrJC7RGaHbxuH
Old Aug 16, 2025 | 09:00 AM
Tri-Carb's Avatar
Did you consider a Group 27 size battery?
Old Aug 16, 2025 | 09:33 AM
Sugar Bear's Avatar
Measure the space available and the size of the battery in it now if there is one, then look at battery dimensions on a BCI group size chart. Also look at the electrical specs for a comparable cranking amp rating.
Old Aug 16, 2025 | 10:04 AM
What group size battery is in it now?
Old Aug 16, 2025 | 11:23 AM
Had an Exide Classic Part # 65C Group Size 65 but was too big and have to have a tarp strap to Hold it in.
Was hoping to find a reasonably priced battery that would at least fit in the tray.
Tried taking measuring tape to several different places but no luck.
Best luck I have had is at Titan Machinery in South Dakota which is a tractor implement dealer. That is where the exide battery came from and wasn't too bad but looks tacky at car shows when you open the hood.
Old Aug 16, 2025 | 11:34 AM
Group 27 are all 8.75 inches tall and that is too tall for factory original ground cable.
Old Aug 16, 2025 | 01:51 PM
Buy a longer ground cable and all the battery sizes will work.
Old Aug 17, 2025 | 07:39 AM
The original battery in that car would have been an R63, which is a Group 60 case. 13" long, 6.25" wide, 8.25" tall. Unfortunately there are no readily available batteries that fit within that envelope. A Group 51 is narrow enough but is 8.75" tall (9.375" long, 5.1" wide, and 8.75" tall) . You might want to consider changing the battery cables. Also note that the Group 51 comes with standard and reversed terminals, so be sure you get the version that puts the terminals in the best orientation for your car.
Old Aug 17, 2025 | 10:14 AM
OP should have no expectation that drop in, affordable, good looking replacements are readily available. Car is 70 years old. Recommend seeing what the 30 billion tri five chevy boomers do.
Old Sep 3, 2025 | 09:01 PM
griffey57's Avatar
I got mine at Costco for my 57 and it is an interstate battery
Old Sep 3, 2025 | 09:57 PM
What group?
Old Sep 3, 2025 | 10:03 PM
griffey57's Avatar
Mine was group 24
Old Sep 4, 2025 | 04:33 AM
x3 on replacing the battery cables. If they're OE they're probably due for a replacement anyways.
I just put 2 Group 27 batteries in my 86 Ford F250. If they're strong enough to turn over a diesel engine with 22.5:1 compression they'd work fine for your Oldsmobile if you could get them to fit.
Old Sep 4, 2025 | 09:10 AM
Mine was group 24
There ya go, @snowmonkeys . Just compare the measurements of that battery with the measurements Joe so thoughtfully provided. Hopefully it'll work for you.
Old Sep 4, 2025 | 12:04 PM
zzcruzin's Avatar
Wal Mart group 27
I am a pretty old and simple guy. Ya,,,,,,,,,,just a little wider, but, it works fine.
Old Sep 4, 2025 | 06:41 PM
zzcruzin's Avatar
battery
As you can see, my braided cable worked fine, close, but fine. As Ralph and Olds64 said, just buy a longer cable. Possibly one like this,,,,,,,,, https://www.ebay.com/itm/196197950382?_
stevenwham
May 16, 2022 05:38 PM
oppeds
Oct 16, 2021 08:27 PM
62 Super 88 Coupe
Sep 29, 2021 01:53 PM
Jon442
May 10, 2021 07:31 AM
JukeboxJohn
Mar 29, 2017 01:04 AM
