15" wheel backspace
15" wheel backspace
I'm once again looking to purchase 15" rims for my 69 442 and am questioning what I should look for in backspacing for what ever I buy. I would like to find either Torque thrust or Torque Thrust II rims to replace my 14" SS2 rims.
What would you guys suggest that I should go for the Max backspace that will both not cause any wheel rub and still fill the wheel wells. I want 15x7 on the front and probably 15x 8 on the rear.
Pics would be great
Pics would be great
Pics would be great
Pics would be great
Backspacing is unrelated to wheel diameter. You want OFFSET to be near zero. Backspace for zero offset will vary with wheel width. A 7" wide wheel will be about 3.75" backspace for zero offset. An 8" wide wheel will be about 4.25" backspace for zero offset.
I saw that Padavano Mini Sermon coming from a mile away. ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
From what I gather, the stud mounting plane of the Olds hubs is about split 50/50 from the wheel well opening edge on the outside and the inside, hence the near zero offset. There is, of course a finite limit on how fat the wheel can be just to fit IN there.
I put a smiley on there. I too appreciate Joe's advice, and it was meant jokingly, as people who don't miss social cues would be able to tell.
I took Koda's comment in the spirit that it was intended. We've traded good-natured barbs like that for years. No offense intended or taken.
gearheads78
November 28th, 2011 01:46 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
