15" wheel backspace
Old May 26, 2018 | 12:28 PM
My2nd 69 442's Avatar
15" wheel backspace
I'm once again looking to purchase 15" rims for my 69 442 and am questioning what I should look for in backspacing for what ever I buy. I would like to find either Torque thrust or Torque Thrust II rims to replace my 14" SS2 rims.
What would you guys suggest that I should go for the Max backspace that will both not cause any wheel rub and still fill the wheel wells. I want 15x7 on the front and probably 15x 8 on the rear.
Pics would be great
Old May 26, 2018 | 01:48 PM
Pics would be great
Backspacing is unrelated to wheel diameter. You want OFFSET to be near zero. Backspace for zero offset will vary with wheel width. A 7" wide wheel will be about 3.75" backspace for zero offset. An 8" wide wheel will be about 4.25" backspace for zero offset.
Old May 26, 2018 | 06:37 PM
I saw that Padavano Mini Sermon coming from a mile away.
From what I gather, the stud mounting plane of the Olds hubs is about split 50/50 from the wheel well opening edge on the outside and the inside, hence the near zero offset. There is, of course a finite limit on how fat the wheel can be just to fit IN there.
Old May 26, 2018 | 07:17 PM
FWIW Joe has helped me out on several occasions which I greatly appreciate and I do not consider any of his responses to be a sermon so please lay off your attitude
Old May 27, 2018 | 12:26 AM
I put a smiley on there. I too appreciate Joe's advice, and it was meant jokingly, as people who don't miss social cues would be able to tell.
Old May 27, 2018 | 03:05 AM
I took Koda's comment in the spirit that it was intended. We've traded good-natured barbs like that for years. No offense intended or taken.
Seff
Wheels and Tires
25
Jun 21, 2023 07:00 AM
Shoreman
Wheels and Tires
Jan 3, 2016 05:30 AM
gearheads78
Nov 28, 2011 01:46 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
