12 bolt axle question
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
I've got a 12 bolt axle from a 1969 Cutlass. Will these axle's go straight into a 12 bolt from a 1969 442? I know the 442 axle has 4:10 gears and is posi, but I don't know the gears in the Cutlass axle, I know it is not posi though.
Please any answers will help, thanks!
I'm a bit unsure of what you are asking.
Do you want to swap an axle shaft from the Cutlass rearend to the 442 rearend?
Or do you want to swap the entire rearend?
Either way, the parts should be interchangeable if they truly are both '69 rears. The '70 12 bolt used different bearings so its axle shafts will not interchange with the '67-'69 12 bolt rears.
They should have no problem swapping provided that they have the same spline count, 28 or 31. However, I am sure that one or both of the resident experts here can give you the hard answer. Jerk one axle out of your existing housing for absolute/definitive data for a good answer. Good luck
The axle in the 442 housing I am unsure if it is original. I know it is a 28 spline. I haven't checked anything on the cutlass rearend. I would have thought that 12 bolts would have had 30 spline axles. I'm wanting to just put axles in the 442 hiusing because it has the better geara and posi track.
John
The 31 spline axles were used in 67 & 68. They came in rear axles with 3.42 & lower ratio gears. The 12 'O' axle actually started in 66,not 67 as some think.
The 4:10 gears were in the Chevrolet 12 bolt that came in the Canadian-built 4-4-2's in '69.
I've never seen 4:10's in the 12 bolt Olds rear end.
You might want to make sure that's not a Chevy "C" clip type rear end.
If it is, the axles are not the same as the Olds 12-bolt.
I'll recount the gears. But I do know the axles bolt in. There are 4 bolts that hold the axle in behind the brake shield. Is there anywhere on the rear housing that would have some numbers I can look up?
Yes, there is a code stamped into the top of the right tube near the vent, but it can be really hard to see. I had to use a wire wheel on these two in order to see the codes.
Also, the gears in the diff may not be the ones it came with from the factory 40+ years ago.
72442conv
March 19th, 2012 07:14 AM
cutlasssupreme71
Drivetrain/Differentials
February 22nd, 2011 11:40 AM
