Hei
Old Aug 13, 2015 | 05:37 PM
71oldsS's Avatar
Hei
Am I correct in thinking that I don't need the resistance wire coming from firewall that would go to the coil with my new HEI? Thanks again for any advice.
Old Aug 13, 2015 | 05:56 PM
Oldsmaniac's Avatar
Correct but you do need 12v to the hei + terminal on the cap so you will need to run a wire or find one that is powered with ignition switch on.
Old Aug 13, 2015 | 06:42 PM
71oldsS's Avatar
Is that in addition to the 3 wires coming from distributor, 1 ground and 2 going on coil? new at this
Old Aug 13, 2015 | 07:38 PM
The 3 wire plug that runs from the cap into the body of the distributer is left alone, its there to remove the cap. You need a 2 prong plug like this the red wire is power and the green is for a tach.
joepenoso
Jun 4, 2014 01:56 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
JoshF85
Mar 15, 2005 10:50 AM
