Directional Signal Fuse issue
Old Aug 18, 2014 | 09:17 AM
70Cutlass_408's Avatar
Hello,
Have a weird issue that just started happening to my 70 Cutlass Supreme. The 20 amp directional signal fuse keeps blowing immediately after I swap it out. After the fuse blows it takes out my tach and my all of my gauges (water temp, oil pressure, and volt gauge). Any insight to this would be a great help.
Thanks a lot.
Old Aug 18, 2014 | 10:57 AM
1970cs's Avatar
Lansing built
You have a short! You have to isolate the short, hooking a multi meter on the load side of the fuse holder, Set to ohms. Then unhook things on that circuit until the meter goes open. Now you have the exact circuit causing the issue.
FYI could be the componet or the wiring to it.
It would help if you had chassis service manual to follow the circuit.
PAT
Old Aug 18, 2014 | 02:18 PM
I swapped out the turn signal flasher and directional signal fuse seems to be working normally and all appears to be normal. Thanks again for your help.
Old Aug 18, 2014 | 06:00 PM
1970cs's Avatar
Lansing built
I am glad that I could help and good job on fixing the issue
Pat
Oldscutty72
Dec 28, 2015 01:56 PM
toyolet23
Apr 2, 2013 11:16 AM
ddx77
May 31, 2010 01:38 PM
VegasDelta
Aug 23, 2009 06:50 PM
VegasDelta
Aug 23, 2009 06:17 PM
