ignition switch removal?
Old Apr 16, 2014 | 04:38 PM
69postman's Avatar
cleaning up my steering column for my 69 442. would like to remove the ignition switch out of the column so I can paint the column and clean up the switch. how does it come out of the column? thanks
Old Apr 16, 2014 | 04:45 PM
Redog's Avatar
Remove steering wheel. Remove all stuff under wheel to gain access to ign lock cyl. Should be two bolts holding it in place. Remove bolts, lock slides out
Old Apr 16, 2014 | 04:53 PM
I think he means the ignition lock cylinder, not the ignition switch.
This is a recurring question.
Try here, here, and here.
Old Apr 16, 2014 | 05:42 PM
69postman's Avatar
yeah, yeah MD the lock cylinder. thanks for the correction
Old Apr 16, 2014 | 07:09 PM
Redog's Avatar
That's what I posted how to do. didn't know there were other threads on it.
Removing the steering wheel is the hardest part
Old Apr 16, 2014 | 07:18 PM
But the lock cylinder is not held in place with two bolts, as you stated, but with a single spring loaded catch.
The switch, on the other hand, IS retained by two bolts (or nuts - I don;t recall).
gwunta
Jun 22, 2024 08:59 AM
Fakser
Sep 26, 2012 05:12 PM
mmurphy77
Dec 1, 2011 06:45 AM
grt05
Apr 29, 2009 04:36 AM
marlo7488
Mar 9, 2008 07:57 PM
