Horn relay
Old Feb 26, 2014 | 12:08 PM
69signal's Avatar
Smile Horn relay
I do have a 1983 Olds Hurst and my horn is not working; I test the horn and they are ok but from the steering column they don't work like they are suppose to. Can any one tell me where to locate the horn relay on my 1983 Hurst?
Old Feb 27, 2014 | 05:37 AM
rjohnson442's Avatar
Mr. Johnson
Not sure where the relay is on an 83 . but have you tested the horn switch itself? 30 years for gunk to build up on the contact could do it. And welcome to the site!
Old Mar 6, 2014 | 08:41 AM
69signal's Avatar
Sorry bro I was out of the country but thanks for the suggestion. I still need to find that relay. Also I am looking for a center console for my 83 Olds/Hurst if you know anyone that has one and wanted to sell it let me know.
Cesar
Old Mar 6, 2014 | 01:15 PM
There is a little panel under the dash, just to the left of the steering column. Its not easy to see, really not easy to get to! Before trying to replace the horn relay try grounding the black wire on the turn signal switch harness. If the horn sounds when grounding the wire you know the relay and related wiring is good.
Old Mar 6, 2014 | 02:45 PM
69signal's Avatar
Matt, Thanks for the advice.
pcard
May 14, 2014 01:21 PM
whosyourdaddy
Nov 12, 2010 08:39 PM
64 Cutlass
Aug 1, 2009 06:22 AM
supersport
Jan 15, 2009 09:43 PM
D Appeldorn
Mar 26, 2008 02:30 PM
