67 cutlass parking brake bulb replace
Old November 18th, 2013, 04:58 PM
pbarney's Avatar
I have a 67 cutlass sup. and I want to replace the dash bulb for the parking brake indicator. It's in a little 'cup' so I wonder how the bulb is removed. Any ideas?
pbarney is offline
Old November 18th, 2013, 05:50 PM
texxas's Avatar
I believe the chrome bezel and lense just unscrew from the front side of the dash.
texxas is offline
Old November 18th, 2013, 06:00 PM
Oldsmaniac's Avatar
It comes out from behind. You push and twist to remove and then the same for the lamp. There is a spring in the assembly to keep pressure on the bezel in the dash. Be careful as these fall apart easily...
Oldsmaniac is offline
Old July 3rd, 2018, 05:43 PM
vickycar's Avatar
dash light spring
say your post on light, do you have any pics on how it holds. my son took it out when replaced dash pad and doesn't remember how to put back, can't find spring. see where bulb turns in holder like rear bulbs but can;t figure out how it holds red lense in
vickycar is offline
Old July 4th, 2018, 06:24 AM
edzolz's Avatar
I believe the red lens just pop's in place. If it will not stay in, use a small spot of clear RTV or contact cement to hold it.
edzolz is offline
Old July 4th, 2018, 02:57 PM
therobski's Avatar
X2-edzolz, been there done that....
therobski is offline
Tiberian Fiend
May 23rd, 2018 07:56 AM
R_CK_R
March 19th, 2015 01:13 PM
19sixty5
November 14th, 2013 03:35 PM
67 black goat
March 17th, 2013 09:00 PM
ddx77
December 3rd, 2011 04:18 PM
Quick Reply: 67 cutlass parking brake bulb replace
