67 cutlass parking brake bulb replace
Old Nov 18, 2013 | 04:58 PM
pbarney's Avatar
I have a 67 cutlass sup. and I want to replace the dash bulb for the parking brake indicator. It's in a little 'cup' so I wonder how the bulb is removed. Any ideas?
Old Nov 18, 2013 | 05:50 PM
texxas's Avatar
I believe the chrome bezel and lense just unscrew from the front side of the dash.
Old Nov 18, 2013 | 06:00 PM
Oldsmaniac's Avatar
It comes out from behind. You push and twist to remove and then the same for the lamp. There is a spring in the assembly to keep pressure on the bezel in the dash. Be careful as these fall apart easily...
Old Jul 3, 2018 | 05:43 PM
vickycar's Avatar
dash light spring
say your post on light, do you have any pics on how it holds. my son took it out when replaced dash pad and doesn't remember how to put back, can't find spring. see where bulb turns in holder like rear bulbs but can;t figure out how it holds red lense in
Old Jul 4, 2018 | 06:24 AM
edzolz's Avatar
I believe the red lens just pop's in place. If it will not stay in, use a small spot of clear RTV or contact cement to hold it.
Old Jul 4, 2018 | 02:57 PM
therobski's Avatar
X2-edzolz, been there done that....
Tiberian Fiend
May 23, 2018 07:56 AM
R_CK_R
Mar 19, 2015 01:13 PM
19sixty5
Nov 14, 2013 03:35 PM
67 black goat
Mar 17, 2013 09:00 PM
ddx77
Dec 3, 2011 04:18 PM
