1962 Starfire Generator to Alternator
Hello Folks,
After much effort to make the original harness work, I have located a replacement harness for my 62 to get a fresh start. But it is of course wired for a generator...
Can anyone advise me per the diagram where exactly to connect my wires for the conversion from generator to alternator?
I read elsewhere to connect the old generator wires together and tape them off. Done. And I have wired the new alternator as shown.
But what do I do with the original red and green wires from the fuse block? Do they need to connect to the voltage regulator, tied into the new red and green from the alternator? Taped off? The red from fuse block already has an eyelet that fits the horn relay post. Am I missing a jumper wire back to the voltage regulator?
Thanks!
Steven
Thanks!
Steven
Stellar,
I have installed a newly rebuilt Delco Remy 10SI, external voltage regulator. The original VR and connections are shown in the attached image.
And there is a GEN light in the dash. I read elsewhere that: "...the warning light simply has +12V on one side and is connected to the regulator on the other side. The regulator grounds this terminal when the alternator is not charging, causing the light to illuminate. When the alternator is charging, you get +12V on the no. 1 terminal, so there is equal voltage on both sides of the lamp and thus the lamp does not light."
I am confused how this can be if the Blue and the brown are taped off together, though...
Steven
Steven
eddieunderground
August 1st, 2012 02:41 AM
