Horn Won't work
Old Jul 5, 2012 | 12:28 PM
brown7373's Avatar
Horn Won't work
The drivers side horn on my 72 won't work. I removed it, got the screw to turn and if I wire it direct to the battery and smack it with a small hammer, it works a little, but only intermitently.
Just what does turning the screw do? Should I be tightening or loosening or what? Why am I supposed to get it turning?
Old Jul 5, 2012 | 01:04 PM
Make sure its getting a full 12v from the horn relay, and the grounds are good. If ti has trouble working off the battery, it may need to be replaced. The adjustment screw effects the pitch. If you turn it in untill it gets kinda raspy sounding and then back it out until it's clear!
Old Jul 5, 2012 | 02:10 PM
Oldsmaniac's Avatar
I believe the screw adjustment on the horn is for tone adjustment....sounds like your horn is shot....
Old Jul 5, 2012 | 02:13 PM
brown7373's Avatar
Yes, I think it's shot. I wasn't sure what the screw did, but if it's just tone, then it's shot. The other horn works fine, so I don't suspect the relay, plus, it hardly works whe wired directly to the battery.
Anyone have a drivers side that works they are willing to part with?
Old Jul 5, 2012 | 03:09 PM
Lady72nRob71's Avatar
The screw is for current adjustment (point gap) - the manual should tell you how to do it and what the current should be (around 5.5A sounds reasonable). Sounds like it just needs replacing if its intermittant. Look on it for the note letter so you get the correct one.
Old Jul 5, 2012 | 03:35 PM
Oldsmaniac's Avatar
Thanks for clearing that up!
Old Jul 5, 2012 | 03:59 PM
coppercutlass's Avatar
Chevy budget Olds powered
Just use your finger and shake your fist out the window while yelling.lol jk. You can test it off a drill battery. I know some horns you can test that way.
Old Jul 5, 2012 | 04:08 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You will only find generic horns at the parts stores. The sound should be okay if you get the correct horn but it is not going to match.
Old Jul 5, 2012 | 04:43 PM
I have only set one, as it is a painfully loud thing to be so close upon!
Old Jul 6, 2012 | 12:31 PM
navvet's Avatar
Roughly the same issue. My horn on the 64 88 works about the third the time. I have pulled horns and cleaned them. I hooked them to a power source and they are nice and loud. I want to change the horn relay...( I have cleaned connections but they are eroding)
I have looked for relays and they run about $60.00. Any place that any of you know that has good pricing?
Old Jul 6, 2012 | 12:55 PM
Before you change the relay, your problem may be behind the steering wheel at the horn contact assy. Try to hook a ground directly to the relay, it gets power all the time, and see if it works.
stevengerard
Sep 10, 2014 03:17 PM
jlelec
Jul 5, 2014 10:28 PM
Rios69Cutty
Oct 18, 2012 04:22 PM
silverriff
Nov 19, 2009 04:49 PM
Denm33
May 28, 2008 07:35 PM
