help with interior bulb #'s
Old May 1, 2012 | 12:27 PM
55coupe's Avatar
I'm looking to replace bulbs in my 55 Holiday, I need the two dome lights above the rear passenger windows and the front courtesy lights that illuminate the floor. I tried my local parts store,but they need numbers and I don't have the bulbs to compare. Does anybody know what numbers these bulbs are? thanks!
Old May 1, 2012 | 03:04 PM
radioburningchrome's Avatar
Owners manual might list them, or try a shop manual.
Old May 1, 2012 | 03:30 PM
GAOldsman's Avatar
"Car"mudgeon
Would it look like this? http://www.bulbtown.com/88_MINIATURE..._BASE_p/88.htm How does the base look? Also is it still a 6 volt system?
Old May 1, 2012 | 04:58 PM
55coupe's Avatar
I checked my owners manual and it lists a no.90 bulb, this car is a 12volt system. I hunted around and think it might be a 90BP, I'm hoping someone with a similar car can go pull a bulb and check! thanks so far.
Old May 1, 2012 | 05:29 PM
Style 212 might have replaced your bulb number. These are the ones used in the red/white interior lights at the bottom of doors.
Try this link for reference:
http://www.gelighting.com/na/busines...r_exterior.pdf
Old May 8, 2012 | 07:14 PM
55coupe's Avatar
I finally found the bulb; it's a #90. used for courtesy, dome, interior lights. It's a single filament, dual terminal type bulb. thanks for all the pointers everybody.
Massdelta
May 27, 2014 02:14 PM
ELECMAN
Aug 3, 2013 10:59 PM
1954Bob
Jan 27, 2013 11:20 AM
FATRATMATT
Jun 18, 2008 08:05 AM
denis
Dec 22, 2006 05:03 AM
