help with interior bulb #'s
I'm looking to replace bulbs in my 55 Holiday, I need the two dome lights above the rear passenger windows and the front courtesy lights that illuminate the floor. I tried my local parts store,but they need numbers and I don't have the bulbs to compare. Does anybody know what numbers these bulbs are? thanks!
Would it look like this? http://www.bulbtown.com/88_MINIATURE..._BASE_p/88.htm How does the base look? Also is it still a 6 volt system?
I checked my owners manual and it lists a no.90 bulb, this car is a 12volt system. I hunted around and think it might be a 90BP, I'm hoping someone with a similar car can go pull a bulb and check! thanks so far.
Style 212 might have replaced your bulb number. These are the ones used in the red/white interior lights at the bottom of doors.
Try this link for reference:
http://www.gelighting.com/na/busines...r_exterior.pdf
