Correct Voltage Regulator 1970 Cutlass
Old Feb 11, 2012 | 05:13 AM
Pacecar's Avatar
Can anyone help me with the correct part number for the voltage regulator for a 1970 Cutlass with A/C ? Thanks
Old Feb 11, 2012 | 05:15 AM
Pacecar's Avatar
Can anyone help me with the correct voltage regualtor part number for a 1970 Cutlass with A/C ? thanks
Old Feb 11, 2012 | 07:16 AM
1970cs's Avatar
Lansing built
regulator
Two are listed for 1970 1119515 V8 exc,Pol,c49 or 442
1116387 No notes
Source wildaboutcars
Pat
Old Feb 11, 2012 | 07:30 AM
1970cs's Avatar
Lansing built
Three listed for 1970 1119515 V8 exc, Pol,C49 or 442 1116382 police w 62 amp gen.
1116387 for 4400 series
Pat
Old Feb 11, 2012 | 07:56 AM
frankr442's Avatar
1116387 is an internal regulator for a 442. Other models had the external regulator mounted on the firewall. 1119515 is the external type.
Old Feb 11, 2012 | 08:11 AM
Lady72nRob71's Avatar
I merged these two threads since they are duplicates. Please do not post duplicate questions in different forums, as it can cause those helping to post (and or look up) the same info twice.
Thanks!
Old Feb 11, 2012 | 08:27 AM
Pacecar's Avatar
Thanks for all the help. the 515 is the common one across the GM platform. was not sure with the higher amp for A/C. Looked thru the assembly manual in the electrical section and did not see a part number
thanks again
Aside from unusual applications, like high output police or ambulance, all GM regulators from about '63 (first alternator models) to '73 (internal regulators - 442s had these a couple of years earlier) are the same.
Just get a GM regulator - mechanical or electronic, your choice - and you'll be fine.
Junkyard regulators usually work.
Old Feb 11, 2012 | 11:07 AM
hookem horns's Avatar
I happy a cheap Wells electronic one from Rockauto. Search the forumn and some members have swapped the cover with the original mechanical one to keep everything looking stock under the hood. Might try that someday.
Old Mar 16, 2012 | 07:52 AM
my442conv's Avatar
alternator amps
for a 1970 442 convertible with 455ci, p/windows, p/door locks, p/trunk
what was the correct amps of the alternator w/internal regulator
Thanks Joe
Old Mar 16, 2012 | 10:21 AM
frankr442's Avatar
Don't have my Olds catalog here at work to see what may have been spec'd originally but the strongest one I see still available in the AC Delco catalog is #334-2115. It's a 63 amp 10SI model, the 12SI models have a different looking case and fan.
Old Mar 16, 2012 | 11:46 AM
507OLDS's Avatar
I have a few original voltage regulators,with the raised "Delco Remy" letters.I can see what the numbers are on those.
Old Mar 16, 2012 | 01:33 PM
frankr442's Avatar
According to the GM parts catalog: 70 442 w/air cond = 55 amp. With rear window defogger = 63 amp.
delta_88_germany
Feb 22, 2014 01:48 PM
CaliBoricua
May 12, 2010 12:15 PM
ow30442
Sep 2, 2008 02:51 PM
rocket69
Aug 14, 2008 09:09 AM
and1stp
Sep 17, 2006 07:31 PM
