1953 Olds 88 Engine Temp, Gas, and Battery guage not working
Old February 6th, 2012, 10:20 AM
lmarquette's Avatar
Post 1953 Olds 88 Engine Temp, Gas, and Battery guage not working
Hi everyone,
Hope you guys can point me in the right direction with some advice on how to fix a problem. The temp, gas and battery guages are not working. However, the oil guage, and speedometer are working just fine. Could this simply be a fuse issue? I'm not familiar with the wiring or fuse layout of the 53 olds. Whats a good start to narrow this fix down?
Thanks!
Lee
lmarquette is offline
Old February 6th, 2012, 12:06 PM
milners32's Avatar
I have no idea about a 53 but, I do know there is a fuse on the 55's that are inside the light switch. Really small about 1/2 long glass buss fuse. not sure of the amps though. The Speedo and Oil do not use electric power.
milners32 is offline
Old February 18th, 2012, 02:53 PM
lmarquette's Avatar
Checked the fuse at the light switch and it was good. Also, changed the fuse to the instrument panel from the ignition switch It was also still good but had a new one. Still do not have working guages. What am I missing??
Old February 18th, 2012, 06:22 PM
chequenman's Avatar
"gAUges" GAUGES.....
chequenman is offline
Old February 19th, 2012, 07:00 AM
lmarquette's Avatar
Thanks for the spell check.
Old February 19th, 2012, 08:24 AM
andy's88's Avatar
Check for a good ground on panel
andy's88 is offline
Old March 6th, 2012, 03:10 PM
lmarquette's Avatar
Managed to get everything working. Wire was split and loose and one of the fuses was out. All good.
ELECMAN
June 11th, 2012 07:31 PM
ELECMAN
May 24th, 2012 05:54 AM
Finn5033
April 10th, 2012 09:23 AM
Finn5033
March 24th, 2012 11:57 AM
toplessrocket
January 30th, 2009 01:23 AM
Quick Reply: 1953 Olds 88 Engine Temp, Gas, and Battery guage not working
