door switches
Old Jun 29, 2011 | 06:11 AM
AZ442's Avatar
door switches
Any idea why my passenger door works the lights correctly but the drivers door only lights the dome? (2) white wires to the passenger door and (3) to the drivers (2) white (1) black.
Old Jun 29, 2011 | 06:27 AM
rocketraider's Avatar
Oldsdruid
Try spraying a little WD-40 or contact cleaner up in the switch, between the shell and the plunger pin. After these switches get some age on them, sometimes they'll get just enough crud on them that part of it won't make contact.
Worse to worse, disconnect the battery and unscrew the switch from the door jamb. You can then clean the contact surfaces good with it out of the car.
One of the wires on the DS is for the key warning buzzer. All the switch does is complete the ground path for the dome light by connecting the two white wires together.
StickW31
Apr 14, 2013 10:05 AM
navvet
Jun 24, 2012 06:36 PM
auto_editor
Jul 24, 2011 02:43 PM
Jakespeed63
May 4, 2008 10:54 PM
silverriff
Mar 18, 2008 06:27 PM
