Cigarette ligther
Old Apr 26, 2010 | 07:05 PM
tim72's Avatar
Cigarette ligther
Looking in the book the cigarette lighter does not have a ground attached to it on the original lighter. The replacements have ground attachments. If I have all the doors open and lights on I blow a fuse. I did attach a ground and that seemed to help some what. Anybody have the corect procedure for installing the cigarette lighter properly?
Old Apr 27, 2010 | 01:34 AM
Aceshigh's Avatar
Anything that has 12V power to it has
1. A 12V lead
2. A 12V ground via wire or chassis.
A good policy to follow is:
If it has a ground wire on it, use it.
BTW if you are blowing fuses, it's most likely because your 12V hot lead
is touching metal and grounding out the circuit and blowing the fuse.
Old Apr 27, 2010 | 02:44 AM
MJAKS462's Avatar
I believe it is supposed to have a ground bracket that grounds it to the dash like the dash gauges have. I will look at mine later if noone else answers.
Old Apr 27, 2010 | 05:41 AM
jaunty75's Avatar
You have to attach the ground wire to a good ground. The original lighter grounded through the body of the lighter, which was attached to the metal dashboard. Makers of aftermarket lighters can't know for sure that every application that someone might make of their product will have this same electrical setup as many more modern cars have plastic dashboards. So they provide both wires, and you just have to run the ground wire to a nearby, good ground.
Beob
Mar 5, 2011 01:45 PM
Phil Glass
Oct 25, 2010 11:20 AM
tim72
Aug 5, 2010 07:51 AM
tim72
Jul 18, 2010 12:16 PM
Bunser
May 24, 2010 05:47 PM
