Cigarette ligther
Old Jun 29, 2010 | 01:55 PM
tim72's Avatar
Cigarette ligther
I bought a after market cigarette lighter from O reillys and found the housing did not fit because it had a longer lenght then the original. I ended up buying the correct one from Year one for $25. In the wiring diagram I only see 1 big orange wire connecting to the back of the cigarette lighter with no ground attachment. Is this correct? The reason I ask is the one from O'reilys had an attachment for a ground. I kept blowing fuses so I figured I had better start from scratch with the correct lighter. Wonder why the after market didn't work?
Old Jun 29, 2010 | 02:30 PM
I don't know anything about the aftermarket version, but the stock lighter (and all other dashboard components) ground through a stamped sheet metal ground plate on the backside of the plastic dash. The lighter housing clamps onto this ground plate when you screw the two parts of the housing together. That's why only a single power wire is required.
Old Jun 29, 2010 | 05:56 PM
tim72's Avatar
That answers the question. Thanks Joe
Old Jun 30, 2010 | 05:30 AM
Lady72nRob71's Avatar
I was wondering if the generic aftermarket lighter parts would interchange - now i know!
Old Jul 18, 2010 | 12:16 PM
hamm36's Avatar
I know this is a simi old post.
Is the back of you cig-lighter a blade contact, or a round contact????
Mine is a blade, but the wire I have for it is for a round contact. I am kind of waiting to see what I should do.
Beob
Mar 5, 2011 01:45 PM
Phil Glass
Oct 25, 2010 11:20 AM
tim72
Aug 5, 2010 07:51 AM
Bunser
May 24, 2010 05:47 PM
tim72
Apr 27, 2010 05:41 AM
