Connect tachometer for Oldsmobile Dynamic 88 1966
Old Mar 14, 2010 | 02:00 PM
LuckyLuke's Avatar
Please I need help, I joined the original tachometer, originally from Starfire model of the console, but the needle always stops at 3000 rpm. Connected to the coil is correct? Thanks
Lukáš Paclt
Czech Republic
Old Mar 14, 2010 | 04:24 PM
70 cutlass s's Avatar
Negative side of the coil.
Old Mar 14, 2010 | 04:55 PM
Jaybird's Avatar
Here's some pics from the 1967 Chassis Service Manual.
I hope this helps.
Old Mar 15, 2010 | 01:32 PM
LuckyLuke's Avatar
if there is a problem in that the tachometer may be removed from six-cylinder engine. Can this be adjusted somehow?
Old Mar 18, 2010 | 05:57 PM
Red Delta's Avatar
Registered Abuser
The tach from the 66 to 67 is different. This is from the service manual for 1966.
If it came from a 6 cylinder engine, I couldn't find any provisions for adjustments in the manual.
Old Mar 19, 2010 | 03:00 AM
Yellowstatue's Avatar
My wife's tach stops at 2800 but that is because the guy that replaced the clock, got the clock in a little crooked (clock in middle of tach 1968) and the needle jams and I have to bump the dash gently to get it to release so maybe your needle is bent
fast67vellen2o
Jan 27, 2018 05:48 PM
g77rvd
Nov 13, 2010 01:49 PM
viper771
Oct 1, 2009 05:10 PM
Flye
Jun 25, 2009 02:34 AM
Florent.turbo
Sep 10, 2008 01:10 PM
