How to connect heater hose? 67 400
Old Jun 22, 2009 | 02:44 PM
Flye's Avatar
Got a spiffy new heater hose from Fusick (67 442 400).
Any suggestions on how it connects to the heater end?
It has a big 'collar' around it, that appears to be glued to the end (edit: I don't think it is glued, it is just heckaciously tight....). Perhaps this is insulation on the heater end. please don't tell me i need to pull heater from inside and then run the hose out the firewall.
Can it be forced up in there with that collar?
Any help?
Dan
Last edited by Flye; Jun 22, 2009 at 03:37 PM. Reason: changed mind on whether it was glued.
Old Jun 22, 2009 | 02:48 PM
gearheads78's Avatar
car guy
The foam will slide down to protect the hose from the bracket on the engine. You still need a clamp for the heater core connection.
It has a big 'collar' around it, that appears to be glued to the end. Perhaps this is insulation on the heater end. please don't tell me i need to pull heater from inside and then run the hose out the firewall.
Any help?
Dan
Old Jun 22, 2009 | 03:38 PM
Flye's Avatar
Thanks.
next question: anybody got a picture of the bracket that would be involved?
Thanks,
Old Jun 23, 2009 | 02:50 AM
Yellowstatue's Avatar
Smile The Mentalist
I can see the bracket in my minds eye and it is the alternator bracket; as the hose passes over the bracket the collar is to protect it from abrasive and hostile activity as the motor wiggles and jiggles
Old Jun 23, 2009 | 04:57 AM
car guy
Yours is probably a little different but this should get you the idea.
Old Jun 24, 2009 | 06:30 AM
Flye's Avatar
Thanks! Got a long way to pull that sucker, based on that.... for time being, I've got it back at the A/C-valve cover area.
Bad looking ride!!!
Old Jun 25, 2009 | 02:34 AM
Red face Oops
I guess you will have to turn your car around...
70Cutrag
Oct 29, 2021 06:47 PM
halfmoontrail
Jan 9, 2013 09:17 AM
matchek
Aug 19, 2012 08:48 PM
viper771
Oct 1, 2009 05:10 PM
Florent.turbo
Sep 10, 2008 01:10 PM
