6v to 12v conversion info please.
Hi all, I'm looking to buy a 49/50 Olds and many have the original 6 volt electrics still. I know that many owners will convert the system to 12 volts but I wonder what differences this will acheive, any ideas?
I know that the dynamo will have to be swapped for an alternator and a 12 volt battery fitted but what other changes would be required? I'm thinking of two main areas, engine related components ie starter and ignition circuit and the rest ie lights, guages, radio and wiring loom. Please let me know and put me in the picture, is it worth concidering? Maybe someone has a link to a guide on this. I will be keeping the car for some time. Thanks
Stuart.
I know that the dynamo will have to be swapped for an alternator and a 12 volt battery fitted but what other changes would be required? I'm thinking of two main areas, engine related components ie starter and ignition circuit and the rest ie lights, guages, radio and wiring loom. Please let me know and put me in the picture, is it worth concidering? Maybe someone has a link to a guide on this. I will be keeping the car for some time. ThanksStuart.
Stuart.
Thanks Joe. If the wiring is in good condition would it take 12 volts instead of 6 volts? To convert the lights is it just a case of getting the right 12 volt bulb fitted into the original holders? If I don't do the conversion I guess I can't fit anything modern like a stereo can I?
