Dash Bulbs
Old Feb 28, 2024 | 02:36 PM
Chuxter's Avatar
1970 Cutlass Supreme
Dash Bulbs
Can I get replacement bulbs for my gauges on my 1970 Cutlass Supreme?
Old Feb 28, 2024 | 03:14 PM
They are either 194 or 168 bulbs, any good parts store will stock them.
Old Feb 28, 2024 | 03:53 PM
Matt's correct. FYI, if you own the 1970 CSM there's a page in the electrical section which lists all the bulbs/lamps sizes/part numbers for each application.
Old Feb 28, 2024 | 09:00 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Replace then with LED bulbs and you dash lights will be much brighter.
Old Feb 29, 2024 | 05:18 AM
VC455's Avatar
Barely Registered
Yes, LEDs give a much brighter outlook, and I went that route too. But be mindful that LEDs will not dim effectively unless you add resistance in the supply wire to the headlight control switch.
Old Feb 29, 2024 | 05:39 AM
69 Hurst's Avatar
Olds Fanatic
I also installed LEDs in mine...the difference is day and night!
Old Feb 29, 2024 | 05:44 AM
jaunty75's Avatar
If you have just an owner's manual for the car, bulb specifications will be listed there.
Old Feb 29, 2024 | 05:47 AM
Old Feb 29, 2024 | 01:27 PM
Dont use a LED bulb in the GEN socket, either the bulb won’t work in the event of a charging system issue, or the charging system won’t power up with the ignition on.
Old Feb 29, 2024 | 06:20 PM
Chuxter's Avatar
ThNks for the help. I've got the bulb figured out. Is there anywhere to get new sockets?
Old Mar 1, 2024 | 06:32 AM
You can buy LED bulbs that are not polarized. The real problem is that the factory alternator system requires the resistance of the filament in the incandescent bulb to trigger the voltage regulator.
Old Mar 1, 2024 | 06:33 AM
Type gm dash lamp sockets into Google
Old Mar 1, 2024 | 01:30 PM
I did not know that.
Old Mar 1, 2024 | 07:09 PM
Amazon Amazon
Old Mar 2, 2024 | 01:47 PM
Chuxter's Avatar
Related question. Mine is a 1970 cutlass and tge lens for the high beam indicator is gone. Can you get a replacement, can you use some type of cellophane or plastic or would it just be easier to get a colored bulb?
Billyboy746
Nov 12, 2022 04:58 AM
fjwhoopie
Oct 18, 2021 06:45 PM
w30brad
Feb 8, 2020 02:41 AM
nanardos
Sep 1, 2013 10:15 AM
Redog
May 23, 2011 08:50 PM
