Courtesy lights stay on help
Old Jun 17, 2023 | 01:48 PM
jopa's Avatar
My underdash courtesy lights stay on and do not shut off till I disconnect battery what would cause this? Thanks
Old Jun 17, 2023 | 01:54 PM
72455's Avatar
1972 U code Supreme
Did you check to see if your headlight switch was rotated all the way over to the left?
Old Jun 17, 2023 | 02:24 PM
And if that is not the issue, you have a bad pin switch in the door frame.
Old Jun 17, 2023 | 05:59 PM
jopa's Avatar
Thanks guys I'll try door jamb switches
BlueCalais79
Sep 7, 2021 04:41 AM
vickycar
Aug 24, 2018 05:16 PM
camron
Jan 3, 2013 02:26 PM
patmills
Dec 6, 2010 06:01 AM
1966_F85
May 14, 2010 03:03 AM
