'88 Cutlass Supreme Classic no turn signal
Old Nov 11, 2022 | 03:14 PM
John Buller's Avatar
A few days ago I noticed that the turn signal was flashing slower than normal and now nothing at all. Hazard lights still work and I installed a new flasher but nothing has changed. Where do I look next?
Old Nov 12, 2022 | 11:05 AM
Sugar Bear's Avatar
Turn the hazards on and hold the flasher that was replaced, if you feel it clicking the incorrect one was changed. The hazards and turn signals use separate flashers.
Good luck!!!
Old Nov 12, 2022 | 03:59 PM
sysmg's Avatar
Flashing slower than normal means a bulb is out. Check all the bulbs front and back to see if they light up. Could be a bulb or a bad socket.
Old Nov 12, 2022 | 07:20 PM
69HO43's Avatar
They also used aluminum wiring in those heaps. Not saying that's the issue, but aging for 35 years never helps those kind of wires. My bet is a corroded bulb socket, but it could be anything without proper troubleshooting.
Old Nov 13, 2022 | 08:46 PM
Thanks guys, I will try to get these ideas checked out as I trouble shoot some more.
Old Nov 20, 2022 | 02:22 PM
Problem solved, found the other flasher tucked up under the dash almost above the transmission tunnel. Changed it after checking all the bulbs, all is good. Thanks for the replies.
Umeracle
Oct 21, 2022 07:00 AM
72455
Dec 22, 2021 09:04 AM
jkeegan
Nov 29, 2017 12:10 PM
46038
Feb 26, 2015 02:17 PM
Olds92
Dec 1, 2011 02:59 AM
