70 AM/FM radio mono?
Old September 17th, 2020, 01:22 PM
gratsoy's Avatar
I bought a two-piece AM/FM radio for my 70. I do not have a rear speaker in this car, and don't intend on installing one. I am wondering if I can still use this radio? Could I simply not install the multiplex unit and instead only install the dash unit?
gratsoy is offline
Old September 17th, 2020, 01:45 PM
Yellowstatue's Avatar
Make sure the speaker fader is all the way to the front speaker.
Yellowstatue is offline
Old September 17th, 2020, 02:06 PM
gratsoy's Avatar
Do you think I would be able to completely omit installing the multiplexer unit if I do this?
gratsoy is offline
Old September 17th, 2020, 02:34 PM
I think so, but not 100% sure.
Old September 17th, 2020, 03:00 PM
Randy C.
rcorrigan5's Avatar
I believe that, without the multiplex unit, you will only get half of the sound because it's a stereo unit, and only half of the sound will be hollow. Here's a better bet - you have a wonderful set-up that someone would most likely pay a good price to get. If it were me, I would try to sell the stereo radio/multiplex unit you have and look for an AM/FM mono radio with or without the fader dial on the right side. An AM/FM radio without the fader will give you what you want now and it gives you full sound on the front speaker. If you get one with the fader dial and the blue rear speaker wire, you still get full sound on the front speaker with the dial set to "front" and it gives you the option of perhaps installing the wiring and a rear speaker, which would give you full sound on both speakers.
I have a factory AM/FM mono radio with a rear speaker installed on my '68 4-4-2 (originally came with just an AM radio/front speaker only) and it sounds great, considering what you got in that day. I have an AM/FM stereo radio (complete with the multiplex unit) that originally came with my '69 4-4-2. To me, the radio in the '68 sounds much better than the stereo unit in the '69. I'm thinking that the technology back in that time for stereo was still somewhat new and it just seems to me the stereo reception is just not as good as just receiving the FM signal and getting full sound on both speakers.
Randy C.
rcorrigan5 is offline
Old September 17th, 2020, 03:04 PM
gratsoy's Avatar
Randy C.
I have heard the same from other people regarding the sound quality. I originally bought the multiplex unit because I wanted the correct 1970 radio - I wasn't aware there was a mono version for '70. I'll have to dig.
I will likely need to let this one go and get a proper unit. This was professionally restored, so hopefully I can find something similar.
Is the multiplex truly stereo sound? I was wondering if it was just a dual mono set up? Seems odd to have the right channel come out from the rear of the car.
gratsoy is offline
Old September 17th, 2020, 03:19 PM
RandyS's Avatar
Yes, multiplex was the first commercial version of FM Stereo. I agree, stereo front and back is not really discernable by the human ear, it needs to be side to side to be really effective (unless you can somehow ride with your head turned.........)
RandyS is offline
Old September 17th, 2020, 03:29 PM
gratsoy's Avatar
Interesting. Were FM mono radio's even an option? I might have to stick with AM...
gratsoy is offline
Old September 17th, 2020, 04:00 PM
Randy C.
rcorrigan5's Avatar
Good point about if the AM/FM mono was even available for the '70 model year. I don't see it listed in the publications that I have. I do see it as a U69 option for '68 and '69 (of which one would have had to order the U80 option if they wanted a rear speaker, too) but I don't see it for the '70 model year.
Randy C.
Old September 17th, 2020, 04:11 PM
Rocketbrian's Avatar
There was a 2 piece stereo unit in 70, a one piece stereo unit in both 71 and 72 and a one piece mono unit in 72. The faces all looked identical except for the lack of a "stereo" light in the 72 mono version. The mono unit was much cheaper to buy than the stereo version, most likely why it was offered. That may be the most suitable radio for your purposes.
Rocketbrian is offline
Old September 17th, 2020, 04:53 PM
Cutlass AM/FM was available in '67.
Old September 17th, 2020, 05:04 PM
72 Olds CS
RetroRanger's Avatar
maybe you could use a dash speaker like this for the stereo sound
https://www.crutchfield.com/learn/bl...ar-owners.aspx
RetroRanger is offline
Old September 17th, 2020, 05:07 PM
gratsoy's Avatar
Only issue is that the olds uses high resistance speakers - I think 10 ohms? So this would damage the radio.
I think I will locate a 72 mono FM unit and put my multiplex unit on the Classified board.
gratsoy is offline
Old September 17th, 2020, 05:10 PM
Gary
VC455's Avatar
Garrett, the Vista Cruiser radio options for 1970 were U63 Deluxe Pushbutton Radio (this is the AM radio) and U58, the unit you bought.
And, as already noted, you cannot modify the multiplex radio so that only one channel is used. The main radio portion has two amplifier circuits and if you don't attach a speaker to the second circuit, you will damage that circuit.
Would it be an option for you to put a speaker under the front seat?
Best wishes,
Gary
VC455 is online now
Old September 17th, 2020, 05:20 PM
gratsoy's Avatar
Best wishes,
Gary
There's certainly a lot of options to make this work - but at the end of the day I'm would be just rigging the radio up to work how it wasn't intended for my car.
The 72 Mono unit is a good option - while 2 years newer, it does match the proper appearance for my car. Plus, it's not un-reasonable to assume that some cars back in the 70's had one of these installed at the dealer when the owner wanted to upgrade to FM from their AM radio.
gratsoy is offline
Old September 18th, 2020, 10:33 AM
Gary
VC455's Avatar
...it's not un-reasonable to assume that some cars back in the 70s had one of these installed at the dealer when the owner wanted to upgrade to FM from their AM radio.
With the same logic, I put a 1971 stereo FM (no separate multiplexer) into my Vista Cruiser.
VC455 is online now
442Harv
October 24th, 2018 07:04 PM
70vista
June 18th, 2016 04:56 PM
442Harv
November 20th, 2015 07:48 AM
Troys Toy 70
August 9th, 2015 10:04 AM
stlbluesbrother
February 5th, 2013 06:10 AM
Quick Reply: 70 AM/FM radio mono?
