Negative Battery Cable Install
Old Jul 16, 2019 | 05:33 AM
jimjific's Avatar
Hello all,
I bought this negative battery cable from Fusick.
Description: Negative Battery Cable, 1966 400 V8, 1967 all
I went to install and then noticed that the pig tail was connected to the engine block end and not the battery post end. I thought this pig tail was supposed to ground the headlight area but it does not seem long enough to do so. Can anyone tell me where exactly this pigtail connects?
Thanks,
Jim
Old Jul 16, 2019 | 09:31 AM
The pigtail grounds to the radiator support, the neg side of the battery should be to the front of the car.
Old Jul 16, 2019 | 11:07 AM
jimjific's Avatar
That is what I thought was the case. I will have to check to see if it is long enough. The pig tail on this harness is off the end that goes to the engine. The 68 and newer have the pig tail going of of the terminal end.
Jim
Old Jul 16, 2019 | 12:14 PM
I see what your talking about now. Can't help you as I've never seen that. Does it go to the alternator.
Old Jul 16, 2019 | 03:17 PM
jimjific's Avatar
My car is a non a/c car so the alternator is on the right side so this would never reach. Maybe I'll call on Fusick. Now that you bring that up though, my alternator harness only had the positive lug and the the push on connector. There is nothing on the ground lug other than a harness strap. See image of back of alternator before I removed anything.
Old Jul 16, 2019 | 07:04 PM
jimjific's Avatar
I think I may have figured out where the pig tail goes. This image shows a machine screw in the left wheel well that line up pretty good and there is no other purpose for the screw that I can figure.
Jim
Old Jul 17, 2019 | 12:29 AM
Hairy Olds's Avatar
Shoveling Snow
67 442 for reference
Old Jul 17, 2019 | 05:16 AM
jimjific's Avatar
Awesome, thanks.
Jim
Old Jul 17, 2019 | 09:23 AM
Mine didn't have the stock cables anymore, sorry I couldn't help.
Old Jul 17, 2019 | 10:30 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Call Fusick and ask. They are always willing to help
Old Jul 17, 2019 | 10:37 AM
jimjific's Avatar
Looks like it is solved. For 67's the negative from the pig tail goes to the inner fender well and not the radiator support.
Platinum69
Nov 2, 2018 02:30 PM
rktolds
Nov 8, 2014 06:53 AM
Mr Shifty Sidney
Sep 28, 2013 05:20 PM
fjross
Sep 27, 2010 06:24 AM
bammax
Aug 13, 2010 08:10 PM
