Connector for Underhood Lamp
Old May 9, 2019 | 09:20 AM
VC455's Avatar
Barely Registered
After my car (1970 Vista Cruiser) came back from the paint shop, the lead that connects to the underhood lamp was no longer in a obvious position. I looked for it but did not find it.
According to the wiring diagram, the brown lead starts out at the Main Lamp Switch. Before that wire goes to the Alternator and Forward Lamp Dash Connector, the underhood lamp lead splices in.
As I read the wiring diagram, that means the underhood lamp lead comes through the firewall on its own, rather than through either of the two Dash Connectors.
My question is, at what location does the underhood lamp wire come through the firewall?
Old May 9, 2019 | 03:29 PM
Here is the engine compartment wiring diagram from the 1970 Assembly Manual. I'll see if there is another more specific to the Vista Cruiser. If I find one, I'll post it.
Old May 9, 2019 | 03:39 PM
Trying to find an image of the firewall wiring for you - might be closing in on it, maybe.
Old May 9, 2019 | 06:50 PM
VC455's Avatar
Barely Registered
Red face
Trying to find an image of the firewall wiring for you...
Thanks, Norm. The drawing shows the lead is spliced in the engine compartment, just a few inches from the Alternator and Forward Lamp Dash Connector.
It shows the lead coming out of the loom at the same point as the Differential Brake Switch wire. I found that and found the Underhood Lamp lead there, tangled in brake lines.
I won't trust the wiring diagram anymore.
jrcpi999
Jul 2, 2019 02:56 PM
VC455
Sep 17, 2017 06:28 PM
craig442
Sep 1, 2016 07:13 PM
whojohnjones
Aug 19, 2016 11:55 AM
Mark71
Aug 15, 2016 06:30 AM
