Fuel guage never goes above 1/4
Old May 3, 2019 | 05:42 AM
deadeyejedi's Avatar
I’ve been cleaning up some minor issues on my 80 cutlass supreme . And one thing on my punch list is the fuel guage it never reads more than quarter tank . It does drop below empty as I use the fuel .Is it almost always a sending unit that causes this problem? What are some trouble shooting techniques I can follow before dropping the tank ? Thank you
Old May 3, 2019 | 08:39 AM
Disconnect the wire at the sending unit. If the gauge moves well past full you know the gauge needle is physically capable of reading above full. If you ground the wire, the gauge should read empty. If all that checks out, time to drop the fuel tank. Either the sending unit float is binding on something (preventing it from moving above a 1/4 tank) or the sending unit is electrically defective.
Old May 3, 2019 | 08:57 AM
Thank you Matt I’m going to check it out tonight honestly I’d rather it be the sending unit than the guage
Reese Jacobs
Aug 4, 2019 07:05 PM
70cutty
Apr 15, 2019 05:04 PM
golden rocket
Aug 30, 2018 11:13 AM
Mike70GoldOlds
Jul 8, 2017 07:57 AM
hamm36
Jan 1, 2009 08:21 PM
