PW motor replacement
Old May 28, 2018 | 08:58 AM
matchek's Avatar
How do you remove the motor ? I have a 68 Oldsmobile 88 . I removed 2 bolts that hold the motor to the door panel. There are two other bolts inside the panel that I cannot reach. Do I need to disconnect the window regulator to contort the motor to reach the bolts? This is so frustrating
I need to take it to a professional.
Old May 28, 2018 | 11:17 AM
The Fisher Body Manual explains the power window system in detail. The easiest way toe replace the motor is to remove the mechanism from inside the door first.
mmurphy77
Feb 21, 2026 08:46 PM
5998DownUnder
Jun 14, 2013 06:03 PM
bgoble
Sep 10, 2010 12:01 PM
Giddy
May 12, 2009 08:21 PM
redrumloa
Jul 28, 2008 06:16 PM
