PW motor replacement
How do you remove the motor ? I have a 68 Oldsmobile 88 . I removed 2 bolts that hold the motor to the door panel. There are two other bolts inside the panel that I cannot reach. Do I need to disconnect the window regulator to contort the motor to reach the bolts? This is so frustrating
I need to take it to a professional.
The Fisher Body Manual explains the power window system in detail. The easiest way toe replace the motor is to remove the mechanism from inside the door first.
