Fuel gauge and other issues
Old Apr 21, 2018 | 03:58 PM
Chris Cutty's Avatar
Hello I am also having similar issues. My fuel gauge is stuck on E. I had the car running and disconnected the wire coming from the tank into the trunk and now my gen light is always lit up when vehicle is running. Also at night the fuel gauge cluster flickers or turns off when driving with the lights on and car hesitates on start up every time. Had the battery tested and was told there is a chance the alternator is not providing enough amperage. I have a 71 cutlass any insight is appreciated.
Old Apr 21, 2018 | 07:34 PM
jaunty75's Avatar
You have multiple problems. The fuel gauge stuck on E, as noted above, means a short in the system. Your flickering lights and gen light issues could be the alternator. You had the battery tested. Have you had the alternator tested?
Old Apr 21, 2018 | 07:48 PM
I moved your post to its own thread as your problem/s are not the same. So if you reconnect the fuel gauge wire do all the other issues go away?
Old Apr 22, 2018 | 07:12 AM
troyd's Avatar
As the other guys have said, if the gauge is on "E" there is a short........the other issue, sounds like alternator. It's about a 10 min job to remove it....go get it tested. A new one is about 80 bucks and about 10 mins to put back on....not a big job (again, if I can do it....ANYONE can).....so not exactly cost prohibitive.
Just as a unrelated side note.....is it me or does it seem really strange that a starter is cheaper than an alternator??
Cheers,
Troy
Old Apr 22, 2018 | 08:01 AM
Your car has an external voltage regulator. Trouble shooting through your wallet gets expensive. Don't randomly throw new parts at your issue, trouble shoot logically.
JPMDaddy
Jan 31, 2020 04:01 AM
lemoldsnut
Nov 25, 2013 12:08 AM
Switch Blade Betties
Sep 4, 2013 09:28 AM
F-85_1964
Feb 21, 2013 06:02 PM
yeahbuddy
Apr 21, 2010 06:32 AM
