Horn not working
Old April 15th, 2018, 08:25 AM
Rick67OldsVert's Avatar
Horn not working
Just to be clear about something I read in another thread, I just jumped the black wire terminal on the horn relay to ground and the horns worked. Does this mean the relay is good and the problem is between the black wire connector and the steering wheel ground? also my key buzzer does not work so could both of these problems be in the steering column wiring/ground?? Thanks, Rick
Rick67OldsVert is offline
Old April 15th, 2018, 09:42 AM
Sugar Bear's Avatar
If the horns work the relay is good, the problem is somewhere between the relay and the horn contact in the column, not the relay itself.
Sugar Bear is online now
Old April 15th, 2018, 10:03 AM
Thanks Sugar Bear. I was glad about that. The relay is pretty pricey.
Old April 15th, 2018, 02:03 PM
Yellowstatue's Avatar
There should be a brass strap connecting the steering shaft at the rag joint to the steering box. Ground path.
Yellowstatue is offline
Old April 15th, 2018, 03:54 PM
Sugar Bear's Avatar
Good advice about that ground strap. IIRC there is supposed to be one from the back of the head to the firewall also...anybody???
Old April 15th, 2018, 04:16 PM
^^^^Ditto that.
Old April 15th, 2018, 04:23 PM
Yes, there should be a braided strap from the rear of the passengers side head to the firewall.
Fun71 is offline
Old April 16th, 2018, 03:42 AM
OK great. I know I have the braided strap to the head but I will check the other one. Thanks again!
Old April 16th, 2018, 07:29 AM
You can jumper to ground the black wire at the connector on the steering column. That will eliminate all the cars wiring except in the column itself. If the horn works there, then take the steering wheel of and troubleshoot the column.
oldcutlass is online now
Old April 19th, 2018, 05:47 AM
I will certainly try that. I had to leave Michigan's unending winter for 10 days in Florida. Thanks for the info. I really do appreciate it!
Bee Saint Louis
October 28th, 2017 08:16 AM
budg
August 31st, 2017 03:29 PM
cbogartjr
August 6th, 2016 04:48 PM
scharpp
April 7th, 2015 10:28 AM
Mattia-SS
August 11th, 2011 01:26 PM
Quick Reply: Horn not working
