Horn not working
Old Apr 15, 2018 | 08:25 AM
Rick67OldsVert's Avatar
Horn not working
Just to be clear about something I read in another thread, I just jumped the black wire terminal on the horn relay to ground and the horns worked. Does this mean the relay is good and the problem is between the black wire connector and the steering wheel ground? also my key buzzer does not work so could both of these problems be in the steering column wiring/ground?? Thanks, Rick
Old Apr 15, 2018 | 09:42 AM
Sugar Bear's Avatar
If the horns work the relay is good, the problem is somewhere between the relay and the horn contact in the column, not the relay itself.
Old Apr 15, 2018 | 10:03 AM
Thanks Sugar Bear. I was glad about that. The relay is pretty pricey.
Old Apr 15, 2018 | 02:03 PM
Yellowstatue's Avatar
There should be a brass strap connecting the steering shaft at the rag joint to the steering box. Ground path.
Old Apr 15, 2018 | 03:54 PM
Sugar Bear's Avatar
Good advice about that ground strap. IIRC there is supposed to be one from the back of the head to the firewall also...anybody???
Old Apr 15, 2018 | 04:16 PM
^^^^Ditto that.
Old Apr 15, 2018 | 04:23 PM
Yes, there should be a braided strap from the rear of the passengers side head to the firewall.
Old Apr 16, 2018 | 03:42 AM
OK great. I know I have the braided strap to the head but I will check the other one. Thanks again!
Old Apr 16, 2018 | 07:29 AM
You can jumper to ground the black wire at the connector on the steering column. That will eliminate all the cars wiring except in the column itself. If the horn works there, then take the steering wheel of and troubleshoot the column.
Old Apr 19, 2018 | 05:47 AM
I will certainly try that. I had to leave Michigan's unending winter for 10 days in Florida. Thanks for the info. I really do appreciate it!
Bee Saint Louis
Oct 28, 2017 07:45 AM
budg
Aug 31, 2017 03:29 PM
cbogartjr
Aug 6, 2016 04:48 PM
scharpp
Apr 7, 2015 10:28 AM
Mattia-SS
Aug 11, 2011 01:26 PM
