67 CS Brake Light Issue
Old Apr 12, 2018 | 07:05 AM
babailey's Avatar
I have a 1967 CS Holiday Coupe. I have intermittent issues with brake lights and turn indicators. They all work most of the time, but none of them ever seem to work all of the time. I suspect this is a ground issue, so my question is:
If I purchase new light sockets for all 4 lights in the back, should I go for the sockets that have an independent ground, or should go for the ones that use the metal socket as the ground?
Thanks!
Old Apr 12, 2018 | 08:04 AM
lemoldsnut's Avatar
Grounds can be an issue. I use those teethy grounding washers on all things that are electrical so they get an extra bite to ground. Some light sockets get worn and become loose over time. I have had the same issues in the past with my 67. I also use dilectric grease on all the bulbs. If you get the new sockets that you ground separately it is kind of a pain but you will be making sure they are grounded. That is not a bad idea in my opinion. New bulbs and making sure all contacts are good. Weather tight and secure is smart.
Just my 2 cents
Larry
harpelt
Aug 19, 2017 01:22 PM
Dustin1706
Jul 9, 2017 06:51 AM
ortarheel
Aug 21, 2015 05:33 PM
NINETY_EIGHT_REGENCY
May 18, 2014 07:12 PM
dan68toro
Aug 12, 2008 11:27 AM
