Wiring hei and gauges, in need of help
Ok I thought I had the electrical manual for the car but I don't. I have several others. Can any one help me out with a diagram. Or tell me where to go off. I want to wire the hei in and need a connection that 12 v on cranking and running. I realise I've asked about the wiring before, however I have no diagram. And I want to make sure its right.
I'm guessing those are the wires. I checked today and it gets 12 volts cranking and in the on position. Is the white fiberglass looking wire the resistor wire. If so how far back do I trace it to replace it with solid copper wire?
The brown'ish wire your describing goes all the way to the bulkhead connector. That is the resistance wire. You can remove the terminal and wire from the bulkhead connector and place some heat shrink over both ends and tape them to the harness. Replace it with a 12ga.
djchunter
Mar 17, 2016 03:57 PM
joepenoso
Jun 4, 2014 01:56 PM
terrapin
Aug 7, 2012 06:25 PM
