Tach reads high
Old Feb 4, 2017 | 07:13 AM
Timmygun1's Avatar
Tach reads high
Question about my tach with standard point ignition. My tach always reads very high every time. Any thoughts? Thanks
Old Feb 4, 2017 | 07:23 AM
I moved your post to it's own thread because it really isn't related to a thread about a Pertronix ignition. In your case the only option is that the tach needs to be recalibrated. Are you sure this isn't set for a six cylinder engine? For example, on the six cylinder setting, a tach would read about 4000 RPM when the V8 engine was turning 3000.
84oldshurst
May 7, 2015 12:16 PM
HurstLightning84
Aug 16, 2012 04:58 PM
ACID64
Sep 7, 2011 11:16 AM
MN71W30
May 25, 2009 04:07 AM
