Alternator Upgrade.
Old August 20th, 2016, 11:52 PM
sammicurr86's Avatar
Alternator Upgrade.
Looking into one of these three to upgrade the Alt for the 70 442. Thoughts? Suggestions?
1. https://www.summitracing.com/parts/f...bile/model/442
2. https://www.summitracing.com/parts/p...bile/model/442
3.https://www.summitracing.com/parts/p...bile/model/442
sammicurr86 is offline
Old August 21st, 2016, 06:34 AM
Originally Posted by sammicurr86
Define "upgrade".
Are you looking for a higher output alternator? If so, why? Or are you looking for bling? Personally, $500 for an alternator is insane. I care about performance, not bling. I use this CS130 - bolt on 105A for under $75.
joe_padavano is offline
Old August 21st, 2016, 06:36 AM
RockAuto's got rebuilt 140A CS-144s for less than $80.
But the ones you picked are very shiny.
Up to you.
edit: looks like Joe beat me to it.
MDchanic is offline
Old August 21st, 2016, 06:38 AM
Up to you.
I'm not sure if the CS-144 bolts to the current brackets. I do know that the CS-130 I linked to is from a 1990 Olds 307 and definitely bolts in place of any 1960s-1980s Olds alternator. That's what I'm running on my 62.
Old August 21st, 2016, 06:43 AM
I thought it did. I'm pretty sure the CS130D (different from the CS130) doesn't.
I picked the 144 because in stock form it goes to 140A, which was in the neighborhood of the OP's selections, instead of the CS130, which goes to 105A stock.
MDchanic is offline
Old August 21st, 2016, 06:49 AM
The CS-130D is a completely different alternator with an internal fan. Here's the CS-130D
Here's a normal CS130
Actually, after more research, I find that this company does CS-130D alternators with the old-style mounting ears, up to 180A for under $200.
The only CS-144s I've seen are from vehicles with serpentine belts (like my truck) and don't have the "normal" GM alternator mounting ears for a V-belt setup. Olds used the CS-130 on the 307s in the Custom Cruiser (and in Caddy Broughams)for 1989-1990 and those do have the correct mounting ears. On my 62 I needed to swap the pulley due to the 215 using a wider V-belt.
Here's a CS-130 compared to a CS-144
Old August 21st, 2016, 07:02 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I am running a CS 130 in my 88 CSC with factory Non A/C brackets, i may have added a washer on the bottom bracket. I bought a Summit 70 amp 10DN chromed replacement. I did have to grind the bottom bracket slightly for it to fit. I was pleasantly surprised with a proof of performance tag stating 51 amps at idle and 82 amps at cruise. Should be good for my Stratus fans.
olds 307 and 403 is offline
Old August 21st, 2016, 07:14 AM
Okay, after some brief research (none of which, I will admit, was first-hand), I have found a description of fitting a CS144 in a 12si application.
Looks like the pivot screw tab is ⅛" thicker and needs to be ground down, the adjuster screw tab is threaded for an M10 screw, which is larger than the original (which I believe is ⅜-16), and so either the adjuster track needs to be widened or the hole has to be drilled and Heli-Coiled, and, of course, the pulley has to be changed.
Not quite a bolt-on, but not a big-deal change if you need the extra 35A either.
MDchanic is offline
Old August 21st, 2016, 07:16 AM
Eric,
What's the application for that 144?
Old August 21st, 2016, 07:19 AM
1992-1996 Cadillac DeVilles, apparently, but I believe the case (not the pulley) should be the same for any HD GM commercial vehicle (police, taxi) from that generation.
MDchanic is offline
Old August 21st, 2016, 07:26 AM
svnt442's Avatar
Eric,
This is what I found Joe.
This part also fits:
Cadillac31 vehicles
1 vehicles199360 Special Base
V8 - 4.9L vin B 300ci - MFI GAS OHV
3 vehicles1991 - 1993Commercial Chassis Base
5 vehicles1991 - 1995DeVille Base
1 vehicles1991DeVille Spring Edition
3 vehicles1991 - 1993DeVille Touring
3 vehicles1991 - 1993Eldorado Base
1 vehicles1991Eldorado Biarritz
1 vehicles1991Eldorado Spring Edition
2 vehicles1991 - 1992Eldorado Touring
2 vehicles1991 - 1992Fleetwood 60 Special
2 vehicles1991 - 1992Fleetwood Base
2 vehicles1991 - 1992Fleetwood d'Elegance
3 vehicles1991 - 1993Seville Base
2 vehicles1991 - 1992Seville STS
svnt442 is offline
Old August 21st, 2016, 07:30 AM
Which was why I was specifically excluding it, in case others reading along did not realize that that one letter denoted a completely different part.
MDchanic is offline
Old August 21st, 2016, 09:43 AM
Define "upgrade".
I'm more concerned for quality/performance and longevity (bling doesn't hurt) but is not necessary. I'm tired of Chinese made junk crapping out after 2 years. If I don't need to spend $500 then great.
Old August 21st, 2016, 10:19 AM
That CS-130D interests me. Good price and less hassle during installation. For the Regulator options I think I'll set it up for external use and pay the extra $35 as I heard one wire Reg is not as beneficial?
Old August 21st, 2016, 10:22 AM
Hey, my Delco reman CS 130 under the Champion brand, is a Mexican POS😊. Hoping this Summit 10 DN 70 amp chrome alternator, since it has very good reviews, holds up. Wish I would have read the reviews for one of their mini starters, what a POS.
Old August 21st, 2016, 10:34 AM
Let's start again.
ALL of the alternators I posted above, in addition to the links you showed, are INTERNAL regulator.
The CS130 and 144 alternators are set up with a very adaptable wiring interface. You can easily wire them with the three-wire scheme, or you can wire them without using the GEN light. This feature is built in to the voltage regulator. These do NOT have the problems of the one-wire 12SI style alternators.
Go back and re-read the posts above. The CS130D is NOT the same as a CS130, and are more expensive.
Old August 21st, 2016, 10:37 AM
ELY442's Avatar
If I was to install this on my 70 Cutlass, do I have to bypass the external regulator and converted to internal?
Will I fry the wires with a high output alternator?
ELY442 is offline
Old August 21st, 2016, 10:40 AM
Yes.
Not unless you have a dead short. It's always good practice to upgrade the wire from the alternator to the horn relay terminal with heavier gauge wire and an appropriate fuse link or megafuse.
Old August 21st, 2016, 05:40 PM
Forgot to ask would I need to upgrade the wiring or can I just use the stock wiring with this CS144 (I would pay the extra $50 for it to function with my external Regulator) ----> http://www.qualitypowerauto.com/cata...Fcategory%3D41
I don't want to deal with wiring just yet, would prefer a plug and play situation as I got other fish to fry first.
Still learning so bare with me
Old August 22nd, 2016, 07:17 AM
Why in hell would you want to do that? The stock CS144 already has a regulator. You want to pay $50 to take that out and make the system LESS reliable????
Since you apparently don't care about optical correctness (since the CS144 doesn't look like the original alternator anyway), simply bypass the external regulator and pocket the $50. Or, better yet, if you still want to spend that money, sent it to me. I take paypal.
We will BEAR with you, but if you start taking your clothes off, you're on your own.
Old August 22nd, 2016, 08:18 AM
Alright now I understand. Like I said still learning. Thanks Joe.
As for the nudity...typos they happen.
Old August 23rd, 2016, 08:32 PM
cjsdad's Avatar
This is a must if you upgrade your alternator to anything above 50 amp output. The factory harness in 1970 had, at most, a 10 ga charging lead which will only carry 30 amp continuous for about 6 feet. You need about a 4 ga wire to carry 100 amp 6~10 feet continuously. The alternator won't put out the current until the vehicle needs it, so unless you install a rock concert worthy stereo (a personal favorite) or a pair of 30 amp radiator fans you will never reach that. Figure out the maximum amperage your vehicle will ever need and add 10% to find the right size charging lead you will need.
cjsdad is offline
Old August 24th, 2016, 10:24 AM
Originally Posted by cjsdad
That's a very cool chart. Thanks for posting. A clarification, however. The reason for increased wire size as length goes up has nothing to do with the current, it's to minimize voltage drop, as the chart does show on the left. The current carrying capacity of a given wire size is fixed, no matter how long, but resistance in the wire will cause voltage drop over distance. This can be a real problem for starter circuits, for example.
Old August 24th, 2016, 02:55 PM
oddball's Avatar
For the straight-across - 6 o'clock - mount, 10DI, 10SI, 12SI, CS-130 (nearly everything GM from mid 60's to early 90's) are 6.6" hole to hole. CS-144 was made with that style of case, although it was somewhat rare and is 7.2" hole to hole. As Joe noted, the CS-130D didn't come from the factory in that kind of mount, but apparently someone found enough of a market to make custom housings.
Some of the info out there is confusing, because the common 3 o'clock mount shared major dimensions between CS-130, CS-130D and CS-144 making those swaps far easier.
The Olds mounting brackets are a little picky about that dimension. I'm sure they can be modified to fit a CS-144, but it may take a little creativity. At least for the driver side mount brackets, early 70's (the H-bracket style and the long-arm-bracket style). I'm not familiar enough with the passenger side mount brackets.
oddball is offline
Old November 7th, 2016, 08:29 PM
ah64pilot's Avatar
I'm looking to do the CS144 swap in Wild Bill...what I'm reading is that the 12SI is 6.6" hole to hole and the CS144 is 7.24" hole to hole so the major obstacle is finding or making a mounting bracket that fits the larger housing. Sounds like a lot of trouble, but for those of us with electric fans we need all the idle amperage we can get. Upgrading to a CS144 opens a whole new world of possibilities, especially in the Powermaster line.
Interesting rabbit hole to say the least...one I'll soon find the bottom of.
ah64pilot is offline
Old November 8th, 2016, 09:44 AM
I don't understand the fixation on the 144. Personally, the custom CS130D noted above puts out far more than you need, and bolts to the stock brackets. Eric linked to a thread that talked about retrofitting a CS144, but that was on a CHEVY with different, and more adaptable, brackets. The stock Olds brackets won't accept the larger CS144 without considerable work. With other alternatives available that don't require that, why bother?
Old November 15th, 2016, 08:48 AM
ah64pilot's Avatar
Because powermaster doesn't make a 12SI in the XS series with the electronic adjustable regulator.
Went with the 150 amp 12SI for the time being anyway.
Old November 15th, 2016, 09:45 AM
delete
droptopron's Avatar
Is this a clone or a real 442? 70 442 came with an internal regulator.
I was looking at this one but I went in a different direction. This one had pretty good reviews.
droptopron is offline
442mark
September 30th, 2017 01:06 PM
68conv455
July 12th, 2011 06:59 PM
Joeypete
June 5th, 2010 08:11 PM
bcg88
July 15th, 2007 06:06 PM
sean000
December 22nd, 2006 06:41 PM
Quick Reply: Alternator Upgrade.
