Battery Cable Routing
Old May 1st, 2016, 05:37 PM
jharsh's Avatar
While replacing the starter in my F-85 Rallye 350 (4 speed) I was questioning the routing of the Positive battery cable.
The service manual shows two different routes. It also shows a starter cable tube, which is not installed. I will be putting an ad in the parts wanted section for one once I confirm my questions. I have attached a image from the manual.
My first question is what does A.M.T and S.M.T stand for? I assume it is a Manual versus Standard Transmission, but want to make sure.
My second question is about the cable tube, is this the same tube regardless of location and just mounted differently?
Lastly, For S.M.T routing it looks like the positive cable should be routed down the valve cover, I am curious what the clamps look like on the valve cover and if anyone knows where I can get some.
Thanks for any help.
jharsh is offline
Old May 1st, 2016, 06:03 PM
Full-time Taxpayer
Qwik71442's Avatar
These
http://www.ebay.com/itm/70-71-72-Cut...item5ae062f3a4
http://www.ebay.com/itm/1968-72-CUTL...hW6N82&vxp=mtr
Qwik71442 is offline
Old May 1st, 2016, 06:25 PM
jharsh's Avatar
That's part of it.
jharsh is offline
Old May 2nd, 2016, 07:16 AM
One for automatic trans (AMT) and one for standard (manual) trans (SMT). The SMT routing over the valve cover is to keep the cable away from the clutch linkage and Z-bar.
joe_padavano is offline
Old May 2nd, 2016, 08:52 AM
jensenracing77's Avatar
I have two of the correct 4 speed battery cable tubes. Here is the listing.
https://classicoldsmobile.com/forums...455-350-a.html
jensenracing77 is offline
Old May 2nd, 2016, 09:12 AM
jharsh's Avatar
Joe,
Thanks for the reply.
I was pretty sure I knew what was meant, I had just never seen A.M.T and S.M.T used before, so I was curious to what it actually stood for, I think it means automated manual transmission and sequential manual transmission. Just a old new guy trying to learn, I can tell you a lot about a helicopter but very little about a car.
jharsh is offline
Old May 2nd, 2016, 09:44 AM
Octania's Avatar
Joe,
Automated Manual seems to be a contradiction of terms.
AutoMatic Trans is my best guess for AMT, I am sure it means the Jetaway/ TH350/TH400 and similar.
Somewhere I recall seeing in the factory lit., probably the part numbers book, that SMT is for Synchro Mesh Trans = the 3- and 4-speed manually shifted units.
Octania is offline
Old May 2nd, 2016, 09:53 AM
You mean like the currently popular "manumatic"?
That's exactly where it is.
Old May 2nd, 2016, 10:03 AM
jharsh's Avatar
Octania,
Thanks, Off to the parts manual I will go.
jharsh is offline
kelly bakies
May 10th, 2015 06:38 AM
ErikW
March 25th, 2013 12:35 PM
matviar
April 2nd, 2012 05:18 PM
JohnNC
January 4th, 2012 01:39 AM
rodan
August 30th, 2010 02:00 PM
Quick Reply: Battery Cable Routing
