Battery Cable Routing
Old May 1, 2016 | 05:37 PM
jharsh's Avatar
While replacing the starter in my F-85 Rallye 350 (4 speed) I was questioning the routing of the Positive battery cable.
The service manual shows two different routes. It also shows a starter cable tube, which is not installed. I will be putting an ad in the parts wanted section for one once I confirm my questions. I have attached a image from the manual.
My first question is what does A.M.T and S.M.T stand for? I assume it is a Manual versus Standard Transmission, but want to make sure.
My second question is about the cable tube, is this the same tube regardless of location and just mounted differently?
Lastly, For S.M.T routing it looks like the positive cable should be routed down the valve cover, I am curious what the clamps look like on the valve cover and if anyone knows where I can get some.
Thanks for any help.
Old May 1, 2016 | 06:03 PM
Qwik71442's Avatar
Full-time Taxpayer
These
http://www.ebay.com/itm/70-71-72-Cut...item5ae062f3a4
http://www.ebay.com/itm/1968-72-CUTL...hW6N82&vxp=mtr
Old May 1, 2016 | 06:25 PM
jharsh's Avatar
That's part of it.
Old May 2, 2016 | 07:16 AM
One for automatic trans (AMT) and one for standard (manual) trans (SMT). The SMT routing over the valve cover is to keep the cable away from the clutch linkage and Z-bar.
Old May 2, 2016 | 08:52 AM
jensenracing77's Avatar
I have two of the correct 4 speed battery cable tubes. Here is the listing.
https://classicoldsmobile.com/forums...455-350-a.html
Old May 2, 2016 | 09:12 AM
jharsh's Avatar
Joe,
Thanks for the reply.
I was pretty sure I knew what was meant, I had just never seen A.M.T and S.M.T used before, so I was curious to what it actually stood for, I think it means automated manual transmission and sequential manual transmission. Just a old new guy trying to learn, I can tell you a lot about a helicopter but very little about a car.
Old May 2, 2016 | 09:44 AM
Octania's Avatar
Joe,
Automated Manual seems to be a contradiction of terms.
AutoMatic Trans is my best guess for AMT, I am sure it means the Jetaway/ TH350/TH400 and similar.
Somewhere I recall seeing in the factory lit., probably the part numbers book, that SMT is for Synchro Mesh Trans = the 3- and 4-speed manually shifted units.
Old May 2, 2016 | 09:53 AM
You mean like the currently popular "manumatic"?
That's exactly where it is.
Old May 2, 2016 | 10:03 AM
jharsh's Avatar
Octania,
Thanks, Off to the parts manual I will go.
kelly bakies
May 10, 2015 06:38 AM
ErikW
Mar 25, 2013 12:35 PM
matviar
Apr 2, 2012 05:18 PM
JohnNC
Jan 4, 2012 01:39 AM
rodan
Aug 30, 2010 02:00 PM
