Wiring Up Electric Choke.. where to run it?
Old Feb 7, 2016 | 10:59 AM
Jake Mack's Avatar
Hey all! Sorry if there's already a thread out there for this, I couldn't find one in searching.
There's an electric choke on the Edelbrock 1406 carb on the '67 Delta 88 that isn't hooked up. I looked at fuse block to see if I can see a spot to run that continuous 12v off of when the key is on, but to no avail.
Is there another wire I can tap into that'll give me that continuous 12v with the key on? Or is there a spot right in front of my face on the fuse block?
I'll try to get a picture up of the fuse block to see what you guys think.
Thank you in advance!
-Jake
Old Feb 7, 2016 | 11:40 AM
My442's Avatar
Easy to tap into the 12 volt power wire to the wipers.
It is key operated.
Old Feb 7, 2016 | 11:49 AM
76olds's Avatar
Hookers under Hood
Joe Padavano, has a good diagram on here with how to hook your electric choke up properly. I'm sure he will see your post and help you out. I don't know how to embed threads here so I can't really help you.
Joe P where are you ???
Last edited by 76olds; Feb 7, 2016 at 11:53 AM. Reason: Missspelled Joe P,s last name
Old Feb 7, 2016 | 12:06 PM
Well, if you go to the Tech Editor's Desk subforum, it's the second sticky there.
Old Feb 7, 2016 | 12:09 PM
Originally Posted by CRUZN 66
Two minutes too slow...
Old Feb 7, 2016 | 12:11 PM
CRUZN 66's Avatar
Olds Fever
Sorry Joe, I just deleted it... I didn't want to be redundant...
Old Feb 7, 2016 | 12:13 PM
In the Reply to Thread window, there is an icon just above the text entry box with a small globe that has a couple of chain links under it: (chain links... get it? ).
Simply highlight and COPY the original URL, then go to the Reply to Thread window, type the text like "Here's the Link", highlight that text, and click on the link icon above. A small box pops up where you can paste the URL you copied earlier.
The result is this:
Here's the Link.
Old Feb 7, 2016 | 12:16 PM
Jake Mack's Avatar
You guys rule! Thanks so much.. will pour over schematics, otherwise, I like the idea of tapping into the wipers. Love this forum!
Old Feb 7, 2016 | 12:20 PM
No need to be sorry. Just pulling your chain.
joe_padavano
Tech Editor's Desk
98
Nov 14, 2025 01:59 PM
240 Gordy
Oct 11, 2020 10:04 AM
shamusj
Mar 4, 2016 06:48 AM
Al Sanchez
Mar 5, 2013 04:49 PM
projectheaven
Aug 27, 2011 04:35 PM
