Wiring Harness Renewal
Old Oct 18, 2015 | 03:24 PM
1968_Post's Avatar
Does anyone have experience with removing these types of terminals from this junction block? This harness was in rough shape but is repairable if I can get the spades out of the block.
Old Oct 18, 2015 | 03:37 PM
mrolds69's Avatar
Looking at the pic, it looks like they are the standard male GM terminal. You can squeeze them with needle nose pliers or jam something to compress the slot and pull them out from the wire side. I'll get a pic.......
Old Oct 18, 2015 | 03:40 PM
m371961's Avatar
One edge of the spade can be pushed to the center enough to allow it to be pulled free from behind. I use a icepick. Once you get it out you will see. If you have one you are not needing do it first. The female terminal is removed by pushing in a tab that is in the middle of the side of the terminal. These are called Packard 56 terminals. http://www.repairconnector.com/packa...-and-housings/
Old Oct 18, 2015 | 04:01 PM
1968_Post's Avatar
Got it... that's hoe I thought they came out but there was so much goop on the backside of the plug that the spade wouldn't release. Once I hit it with enough Brake Kleen, it loosened right up. Thanks for the replies.
Old Oct 18, 2015 | 05:29 PM
FYI, those are Packard 56 series terminals and are available from a number of sources if you need new ones.
pete324rocket
Jan 5, 2013 08:03 AM
mugzilla
Oct 22, 2008 12:06 AM
Olds64
Oct 3, 2007 05:34 AM
elmo
Sep 23, 2007 02:49 PM
stuart
Aug 14, 2004 02:24 PM
